Can someone cast some light as to why cops in Perth have nothing better to do than pull over performance cars for the most piss weak reasons and continually harass the drivers of these cars for no apparent reason as well.
Long story short, was driving along in East Vic Park doing the speed limit and what do you know, a marked car goes past and instantly turns around to pull me over. Their excuse - my window tint was too dark, what a load of f**king bullshit!!
As I don't have to say anymore, they stickered my car.
I took it over the pits at Welshpool and as I expected they picked the shit out of it. Just some of the faults they reckon are -
1. Too low - need 100mm clearance, which it has but the exhaust can is a little lower by 15mm WTF?
2. No load rating stamped on the 255's on the rear
3. Front mount Intercooler installed and as a result I had to remove the front bumper support. The intercooler is like a structural member and much stronger than the piss weak piece of flat steel that it replaced.
4. No battery box for ventilation
If anyone knows of a mod or a bracket I can fit so I can keep my front mount Hybrid Intercooler would be great.
Ok enough whinging
If it has Tyres or Tits
Its gotta be FUN!!!
https://www.sau.com.au/forums/topic/313956-conniving-canary/
Im not suprised, my car got a yellow for only 1 reason - the lowest point on my car (my dump pipe) was 90mm off the ground, only 10mm off the legal limit
funny thing was, i gave way to him as he passed me at a round about and then later down the road, around 100m, he stopped at a bus top, waited for me to pass, and then sped up behind me, right up my ASS.. then sirens come on.. im thinking..... wat the f**k man, ur kidding me.....
then hes like, this is a random license and breathaliser check, im like bullshit! (in my head ofcourse) acted all nice and polite, and he still slapped on a yellow
some cops really have their priorities ALL WRONG, anyone who challenges me on this should be shot!
I love these.
1:
The lowest point of your entire car and ALL of its equipment must be above 100mm.
This is not just to stop you from looking like a jack-ass, but its practacle.
2:
What cheap ass brand tyres are they ?
3:
Sorry buddy, but your intercooler is NOT stronger than your crash bar....your intercooler was probably installed for aesthetics and power you don't really need. The crash bar is there to save you, and your car. Again, don't do shit the cheap way - install the intercooler properly without cutting / shutting, and you have no drama's. If you need to cut the bbar to get it in there, the intercooler is too big. You don't need an intercooler too big to fit in there without structural modification.
4:
This is a simple ADR ... no comment.
Hmmmm, battery box? Now I have to admit, this one has me worried and a little confused. What does this actually mean in the context of having the battery in your boot? Mine is just sitting on a plastic dish (the one that came with the car) and clamped down (like it was when it came with the car). Is this stickerable?
R33's came with special batteries which allowed a tube to be plugged into the battery. This tube then went down thru a hole in boot and out under neath somewhere. This allowed the battery to ventilate. If you have changed your battery to an australian one, then i doubt it came with this modifcation on the battery.
There is also vents in the boot it self, bottom drivers side in the corner.. Take a look. Im sure that these are there due to the battery being in the boot.
I am running a jap spec battery so ive managed to keep that tubing. IF i was to go Australian type battery, i would just get a dry cell which doesnt need ventilaton as far as i am aware... =)
Edited by br3ndan
This.
why do tools like nic comment crap like that?
its like total cop talk
Legality says the car has to have 100mm clearance...which it does EXCEPT for the exhaust which is 15mm low. Sooooo it actually doesnt have 100mm clearance?
All tyres have to have load ratings on them.....his tyres do not.
To cut or modify a main structual part of the car is not allowed. Never has, never will....so why is it a problem that they picked that?
Not sure why you thinks its 'total cop talk'.
+1
Keep your car legal, it's not that hard.
15mm difference in height isn't even noticeable visually, but it is illegal. So just get your car raised 15mm, it will look exactly the same but will be legal. Not a big deal
If your car doesn't have 100mm clearance, you won't make it over the pits, literally.. there is a lip on the edge of the pit you have to clear. Stupidly low cars are silly anyway, best thing I ever did to the skyline (other than the 3L :)) was raise it up off its' balls. Handles better, better bump steer characteristics and no longer had to fear speed bumps.
Edited by bubba
Guest
    • Maybe I also should have wrote that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
    • Hence why I said earlier that I don't think the turbo Neos ever would have actually qualified as an LEV. I suspect the only actual LEVs that came out of Nissan were the NA Neos. Still call them all Neos. They all stil have the Neo-ness. Just that they don't all qualify as as LEVs.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
