got a few bits sitting round;
hicas lock bar...$20
oldish nismo steering wheel...$20
r32 gauge cluster 95,000km....$40
stock rb20 injectors....$50
stock rb20 coilpacks....$50
rb20 loom...$100
r32 ABS unit, all solid lines and bmc included...$50 (if you take the loom aswell its just a simple plug and play)
r32 air con stuff, compressor, air con radiator thing...$40
r32 3inch cat back exhaust, one mid muffler, sounds tuff....$300
r32 stock cat back...$50
3 inch front pipe...$50
r32 coupe boot lid, bogged over spoiler holes, needs paint...$50
rb20, 115,000km minus air flow meter and turbo...$500
rb25 high flowed turbo, only done approx 20,000km if that, made an easy 220kw on rb20 with supporting mods, no shaft play...$1000
all items located in melb, inspections welcome, pm me please
https://www.sau.com.au/forums/topic/313970-r32-random-stuff/
probly best to sms me on 0402 572 813 (cant answer whislt at work so text is best)
also have a little mechanical blitz boost gauge(missing the globe, get one from jaycar for a couple of bucks)...$40
and a generic front mount kit for 32 and 33, mounts upside down...$250
  • 3 weeks later...
  • 3 weeks later...
hey man its andrew, thx for the loom and cooler, plugged the loom straight in and started up first click! haha i dno what the hell happend to the old loom but it was fkd, i mounted the cooler and dumy fitted the pipes and its all good hopefully wil be finished 2moro thanks alot for ur help man if i need any other stuff ill pm ya :thumbsup:
hey man its andrew, thx for the loom and cooler, plugged the loom straight in and started up first click! haha i dno what the hell happend to the old loom but it was fkd, i mounted the cooler and dumy fitted the pipes and its all good hopefully wil be finished 2moro thanks alot for ur help man if i need any other stuff ill pm ya :D
no worries, good to hear its running
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
