Hi Guys, i have some randon parts i need to clear out...
Series 2 Coil Packs... was working when i took them out, no cracks that i can see: $100
GoFastBits Atomic Boost Controller...perfect condition: $50
JustJapRacing RB25DET Split Dump Pipe...perfect condition (comes with little attachement to assit with 'splitting' airflow from wastegate: $50
JJR RB25DET Engine Damper, i have slightly modifies the top bracket to suit a Nismo Stut Brace...that way it all fits: $50
Catco Compliance Cat...2.5" flanges, straight fit for R33 Gtst, only 1-2000Kms old: $100
Clutch Industries RPM Organic Clutch, this clutch is in great condition...i actually have the exact same clutch in my car right now...long storey here but basically i ended up with two kits.
Standard Fly Wheel is separate but available if you want...
Clutch Kit: $200
Flywheel: $100
All items are in my wharehouse in Botany.
Plase PM to discuss pickup or postage...but some items wont post to well...
https://www.sau.com.au/forums/topic/313990-parts-for-sale-r33-gtst/
Hey matey,
Do you have specs for the clutch?
What is the clamping pressure of the pressure plate?
I'm looking to give the 33 a "new" clutch but want one a little stronger than standard.
Cheers.
Here is some info on the clutch guys:
http://ciperformance.com.au/rpmpage.html
the the cat is a 'complaince' cat as stated, just standed flow of around 470cfm...
  • 1 month later...
