Hi Guys, i have some randon parts i need to clear out...
Series 2 Coil Packs... was working when i took them out, no cracks that i can see: $100
GoFastBits Atomic Boost Controller...perfect condition: $50
JustJapRacing RB25DET Split Dump Pipe...perfect condition (comes with little attachement to assit with 'splitting' airflow from wastegate: $50
JJR RB25DET Engine Damper, i have slightly modifies the top bracket to suit a Nismo Stut Brace...that way it all fits: $50
Catco Compliance Cat...2.5" flanges, straight fit for R33 Gtst, only 1-2000Kms old: $100
Clutch Industries RPM Organic Clutch, this clutch is in great condition...i actually have the exact same clutch in my car right now...long storey here but basically i ended up with two kits.
Standard Fly Wheel is separate but available if you want...
Clutch Kit: $200
Flywheel: $100
All items are in my wharehouse in Botany.
Plase PM to discuss pickup or postage...but some items wont post to well...
https://www.sau.com.au/forums/topic/313990-parts-for-sale-r33-gtst/
Hey matey,
Do you have specs for the clutch?
What is the clamping pressure of the pressure plate?
I'm looking to give the 33 a "new" clutch but want one a little stronger than standard.
Cheers.
Here is some info on the clutch guys:
http://ciperformance.com.au/rpmpage.html
the the cat is a 'complaince' cat as stated, just standed flow of around 470cfm...
  • 1 month later...
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
