Here's the details:
Model: BNR32 GTR
Year: 1992
Colour: Red metallic mica (factory colour)
Kms: 123,xxx on 300K dash odo, old speedo had 170,000.
Condition: Body and chassis is fair, paint is crappy close up, eng is forged and has done 23,000km since rebuild.
Aircon works well, climate control works, power windows, mirrors etc all work.
Here's what it has:
genuine nismo front bar vents, and three piece genuine nismo side skirts.
rear quarter skirt pods
18x10 400R rays nismo 3 piece wheels with 265 nexens all round
uas front brake upgrade (324mm 2 piece rotors with billet dogbone spacers)
uas brake air deflectors
cusco brake master cylinder brace
Tein super street coil overs bought new, 1.5 years old, height and damper adjustable).
whiteline adjustable roll bars front and rear
uas adjustable front camber arms
uas adjustable front castor arms
whiteline rear offset camber bushes
uas chrome moly lock bar, all rear wheel steer solenoids and plumbing removed
uas urathane rear cradle bushes, (stock ones are hydraulic filled and break down
front and rear strut braces
uas front triangle braces (fit behind front guards for rigidity)
Engine:
stockR33 GTR engine that was in the car when I bought it, never blown and bloody reliable, then had to get the keyway fixed, so engine out.
Block was bored and honed 20thou (.5mm)
tomei oil restrictor
ACL forged pistons
Spool rods with ARP bolts
R33 crank (oil pump drive is longer on these one's so sweet.)
R33GTR oil pump
Ross metal jacket balancer
tomei 260deg cams inlet and exhaust with clearances checked and shims adjusted
HKS cam gears
Port matched stock exhaust manifolds
HKS 2530 turbos
HKS dump pipes
uas front pipe
barrel cat converter (metal cat)
HKS Hi power exhaust
Just jap air oil separator
catch can
toyo tube and fin intercooler
HKS intercooler hard pipes with t bolt clamps
Extreme carbon fibre twin plate clutch, 3000Km old
R33 GTR gearbox converted back to push type clutch with R32 transfer case
nismo gear knob
nismo oil cap
nismo radiator cap
alloy radiator
sard 700cc injectors (8 months old)
bosch 044 fuel pump in tank
Electrical:
300k speedo
Power fc with hand controller
80mm Z32 AFMs
HKS EVC 4 boost controller
oil pressure and oil temp gauges in glovebox
G redy turbo timer
Panasonic head unit
Pioneer 5x7 front 2way speakers
Kenwwod 2 channel amp and 10 inch sub
Was tuned to run up to 20PSI on 98octane and made 363RWKW tuned at MRC in Castlehill
oil and filter changed every 3000km
Running on 15PSI every day
Only used BP ultimate
around town average 400KM per tank
Hwy km 550Km per tank
A few things that are wrong with the car:
paint is crap close up (needs a respray), when I bought it, it had already been resprayed in the past.
front left tow hook is bent at 45 degrees
left door has two 50cent sized dents
Drivers seat has some wear on the side bolster where the seat belt rubs on
I need to sell this vehicle to purchase my dream ride lol.
Have been to a few SAU events so some of you may have seen it.
Rego till 9 Feb 2011
Price is $20,000 negotiable.
PH: 0412989491
PM for any questions
Pick up only
Richmond Sydney NSW
Cheers,
Sean
https://www.sau.com.au/forums/topic/313992-bnr32-gtr-for-sale/
Thanks guys.
Also has:
Mines cam cover baffles
Splitfire coil packs
8 month old stock fuel reg
Tomei head gasket and metal intake gaskets kit
HKS metal exhaust manifold gaskets
gates racing belts
I'm negotiable on price as I need the money, got another line in my sights!
How bad is the paint? (Any close up pictures of the badness?) Got any interior photos? Receipts? Stock diff? How many kms have the turbos done? Any other outstanding issues? (Fault codes, HICAS disabled etc etc).
Oh and so given the rebuild it is safe to assume this motor won't starve of oil and blow up?
Cheers, (Feel free to PM).
Adam
Edited by OBaYBe
Dream ride, R34GTR, vspec.
Ferrari F40 is out of my price range lol!
Well close up it could do with a respray, plenty of reciepts!, stock diff- yes, running castrol synth lsd oil.
Turbs done around 40,000km
Hicas disabled for rear steer, high/low speed steering sys as per factory (no heavy steering at low speeds).
Well the engine has the stock sump and baffle still, so I have always filled it with 6litres of oil, due to the dreaded oil starvation GTR's suffer.
I keep an eye on the aftermarket gauge to confirm it's not dropping oil pressure when accelerating, and it doesn't.
Like anything if treated properly, warm up, service it and don't bang em off the rev limiter, it's bulletproof.
If you track day a modified GTR, more oil mods would be needed such as, oil drain from back of the head to sump, tomei baffle. All covered in sydneykid's thread?
More pics, like interior, under the car etc, I'll post tomorrow when I get back to syd.
Sorry to hijack thread but how did you fix the heavy steering at low speeds??
Computer is still hooked up, and there is a dummy resistor load where the rear solenoid and front one used to be for the Hicas.
damn good luck with the sale Sean! I remember chatting to you at the 10th Anniversary R34 GT-R Cruise and you were saying to my cousin how most of the stuff you'd done in your backyard! crazy stuff! definitely a talented guy!
Thanks Nick, only thing I didn't do was the tune, that was best left for dyno tuner!
Went on the SAU Bells cruise today and it was great, nothing wrong, all tight, no knocks and rattles, handled great.
No one want to look and offer?
Spec V, nice ride, if I was after a 33GTR I would definately check yours out, looks great!
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
