I am thinking of fitting white dials to my dash in my r33.
few questions for the guru's.
I done it before on a vn. easy. pull needles off, attach dials and replace.
i done it in a vlt. pain in the arse! once you pull the needle off, the mechanism floats around - the needle could go backwards. whereas the vn didnt. so, therfore i had to re-zero the speedo myself via trail and error.
so the question, even with the needle bump stop in place. once the needle is taken off.... does the mechcanisim float? or is it anti backwards mechanisim?
i hope someone out there understand what im talking about.
https://www.sau.com.au/forums/topic/313999-r33-dash-cluster/
someone asked this question last week or something..
someone else said to not remove the needles.. and to slip the white plate over the needle and it should sit well.. try search for the thread for more info
