hey guys, i have an r32 gtr thats always run well, that is untill now.
i started it this morning to move it out of the driveway and theres a massive knock coming from what sounds like the top end.
it gets faster if you increase the revs and sometimes seems to go quieter for a second or two.
the car seems to run fine still, although i havnt gone out and flawed it because that could only make things worse.
i thought it could be a valve, a spring or a lifter but im not sure.
the car is very stock, still with airbox and all. no boost or turbo work.
ive searched for a while and havnt come across anything usefull too.
any help would be greatly appreciated!!
ill record what it sounds like and post it also.
thanks heaps guys!
https://www.sau.com.au/forums/topic/314045-top-end-engine-knock/
if it is the valve guides, how hard would they be to fix?? ive had a bit of mechanical experience although i tryed to get the gearbox out once and failed on the top bolt.
would i need any special tools also??
thanks!
Edited by Sykes
Cost me 700 for the head reco,33gtst but,not sure what an r would cost,i ended up paying 2600,but i had timing belt an stuff done as well,hope it doesn't cost you to much. Genelle. :) This is a fairly big job cams an head off,if you arn't sure get a mechanic to do it.
