Hi guys whats the best suspension you can put into the front of a mr30, i currently have lowered springs and it looks like pedders shocks, i have adjustable konis in the rear, but want somthing adjustable in the front, does anyone know if anyone makes them and who to get them through.
Cheers Alan.
https://www.sau.com.au/forums/topic/314123-mr30-front-suspension/
Cheers Alan.
What's wrong with adjustable Koni's for the front too?
Your rears ............. internally or externally adjustable?
Cheers, D
you can get standard shocks that are adjustable.
just cos they are adjustable doesnt mean they are coilovers.
if you want coilovers, use the search function. you will find that the S13 silvia coilovers are useable. quiet a few extra parts needed though.
its been asked 100 times before.
if youre real clever you can make your own...
Do you have rear coil overs or standard shocks?
The stock rears have the spring over the shock, but they are not coil overs as such.
You can buy Koni inserts for your stock struts & they are internally adjustable.
Cheers, D
thanks Andrew ill have a look into it..
the rear are a koni coilover i dont think they are an insert ill have a look tonight and let you know tomorrow.
Didn't say the rear was an INSERT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fark it ................ why do I bother with idiots
made me giggle a bit...
Tell me tho D, why is the rear not a coil-over... To my mind, a coil-over is just a shock abosorber with the spring seat on it...
appreciate if you could explain that to me.
MY308U - When you say adjustable, do you mean the compression and rebound are adjustable in the shock abosorber, or that the springs can be wound up and down to adjust ride height???
Cheers,
Daewoo
Cheers,
Daewoo
Darryl,
We commonly refer to coilovers as being multi height adjustable as well See Pic 2 JIC. That is wind them up & down to suit your need, but a standard factory set up in the MR/HR/DR30 rear is only height adjustable with a/mkt shocks with multiple slots for the spring circlip that holds up the spring seat.
And the Koni shocks & insetrs are only compression adjustable and the rebound sorts itself out from the adjustment. They have about 2 turns in the adjustment and have to be done before assembly with the spring.
As nothing has been said about what he has, I'm guessing he has a stock set up & really needs the Koni front insert, p/n 86-2224 for his stock struts and puts whatever springs he chooses with them.
D
Darryl,
D
Thanks D,
So we are both right... Coilovers don't have to be height adjustable, it is just that now the name is usually reserved for adjustable suspension... I thought I was going mad...
So if a macpherson strut suspension is also adjustable, is it now referred to as a coilover or as a strut???
In my experience, adjustable suspension is a bit of a waste of money... even when I was swapping between circuit racing one weekend (wanting the car low) and rallying the next (wanting the car high) I rarely adjusted it... every time you adjust the car, you need to get the wheel alignment done again (even though I was getting free alignments it was a hassle) and also, the car is usually out of the optimum height for the shock absorber...
The idea of getting road suspension and then 'dropping the car to the deck' for a track day will usually have your handling and lap times going backwards...
Cheers,
Daewoo
Thanks D,
Cheers,
Daewoo
Dunno about that!
You would suggest these are coil overs when the only hieght adjustment is in the length of the spring.
D
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
