RBChris Posted March 29, 2010 Share Posted March 29, 2010 hi, i must of accidently changed the setting on my power fc to read as a bar/graph instead of a numeric value, how do I change it back to read a numeric value? Link to comment https://www.sau.com.au/forums/topic/314142-powerfc-changing-knock-sensor-reading/ Share on other sites More sharing options...
paulr33 Posted March 29, 2010 Share Posted March 29, 2010 press UP when you press up under any monitor mode, it shows you the top score, ie peak for that value pressing UP on the knock display gives you the digital knock value, 60 flashes the engine check light Link to comment https://www.sau.com.au/forums/topic/314142-powerfc-changing-knock-sensor-reading/#findComment-5155695 Share on other sites More sharing options...
LittlesumoS15 Posted March 30, 2010 Share Posted March 30, 2010 press UPwhen you press up under any monitor mode, it shows you the top score, ie peak for that value pressing UP on the knock display gives you the digital knock value, 60 flashes the engine check light ^^ As above. And read that man's FAQ/Bible on the PowerFC in his sig. Best PFC guide ever on the interwebs. Link to comment https://www.sau.com.au/forums/topic/314142-powerfc-changing-knock-sensor-reading/#findComment-5158789 Share on other sites More sharing options...
RBChris Posted April 1, 2010 Author Share Posted April 1, 2010 press UPwhen you press up under any monitor mode, it shows you the top score, ie peak for that value pressing UP on the knock display gives you the digital knock value, 60 flashes the engine check light thankyou Link to comment https://www.sau.com.au/forums/topic/314142-powerfc-changing-knock-sensor-reading/#findComment-5161771 Share on other sites More sharing options...
