Parting out a complete series 1 R33 GTST
If a part you are after isn't listed, just ask.
Parts are located in Ipswich, QLD
Postage not included - buyer to arrange own post for large items
PM, Post or text 0414 249 292 (only call after 6pm)
Engine/Driveline stuff
RB25det - complete engine with all ancilliaries - $1250 (has HKS cam gear, polished CAS and polished cam covers)
Garrett GT3076R BRAND NEW - .6 surge ported comp cover, .86 exh housing, external gate - $1600
Garrett GT3582R exhaust housing, .82 - $250
Jun "style" inlet manifold, still over $800 new on ebay - $600
BMI 86mm billet throttle body - $250
Deatschwerks 740cc injectors (straight fit in factory rail) - $450
SARD FPR, with gauge and adaptor for factory rail - $150
Walbro 255 l/hr intank fuel pump, BOSCH 044 external and 500ml surge tank, with all fuel hose required for fitment - $300
Performance-wise Oil cooler and filter relocation kit - $200
MSpec aluminium radiator, pretty sure it's 45mm - $200
KTS Intercooler, 600x300x100, 3" in and out - $200
FMIC, 600x300x70,3" in and out, BRAND NEW - $150
Tial 38mm wastegate, slight grinding marks from fitment, perfect working order - $250
Highmount steampipe manifold with merge collector (similar to 6boost), T3 flange and WG flange for Tial gate, will need WG pipe modded to fit a 25, straight fit for 25/30, HPC coated - $350
Excedy twin plate clutch, plenty of meat left - $1000
Lightweight chromoly flywheel, good condition - $250
RB25det gearbox - was perfect previously was a bit clunky going into gear after i dragged it through the tunnel with the shifter in (only driven for 200 metres since), hence price - $1000
5Zigen 3" cat-back exhaust with oval muffler, quiet and was flowig 450rwhp - $250
Splitfire coil packs, perfect working order - $350
JJR GTR polished alloy washer bottle replacement with oil catch can, has been separated but can be re-welded - $100
Turbosmart Type 2 plumb-back BOV - $150
R33 non ABS diff, shimmed a few years ago, still nice and tight - $100
Suspension/Brakes
Sydneykid whiteline/Bilstien springs and shocks, circlip adjustable, 5000km use - $1000
Whiteline fixed front and rear swaybars, not sure of size but the biggest fixed ones they make - $350
Adjstable Rear upper camber arms - $100
HICAS lock bar - $50
Front adjustable castor arms - $100
Front strut bar, polished - $100
Rear strut bar, factory - $100
Front brakes, with RDA slotted rotors and Ferodo DS2500 pads, hardly any pad wear - $300
Rear brakes, stock - $150
Starcorp Impul rims, white, deep dish rear, 18x8.5 F, 18x9.5 R, some gutter rash, ss595 rears with 75%, Nexen fronts need replacing - $1000
Electronics
Haltech E11v2 with R33 patch loom and 3 bar MAP sensor - $1000
Blitz dual SBC EBC, the older black one, dual solenoid good working order - $250
NISMO clear side winkers - $50
Auto gauge 2 1/4" inch stepper motor gauges, smoked, with all senders - Oil Temp, Oil Pressure, Boost - $60 each or $150 for all three
Pioneer CD/MP3 headunit, basic model, black, removable face - $50
Jaycar response 4ch amp - $100
Fusion 12" sub in box- $50
Body & Interior
Garage Defend carbon fibre air guide, perfect fit for GTST, good condition - $400
NISMO GT shift knob, excellent condition - $50
Series 2 steering wheel, very good condition - $150
Series 1 headlights, sedan model with silver inserts, excellent condition - $300
Rear lights, black - $50
Series 2 rear wing, black, with boot - $100
Type M front bar, black, stone chips so needs paint, meshed with high quality case mesh - $250
Type M side skirts, good condition - $150
400R side skirts, 1 has a slight crack otherwise a really well made set of skirts, gunmetal - $150
Type M rear pods, black, good condition - $80
Series 1 dash surround, very good condition, has been stripped and repainted - $100
Centre console with gear surround and ashtray, good condition, gear surround stripped and repainted - $100
Drivers side window switch panel - $100
Series 2 seats, front and rear, drivers side has tear in bolster - $50
Interior carpet and boot trim - $60
Seatbelt stay, the swinging thing that holds the seatbelt off your neck - $40
More to come as I think of it
Reasonable offers considered but lowballers will be ignored
Pics to follow
  • Replies 104
Other bits I have remembered
Garrett turbo beanie, fits GT35R and others - good condition - $100
Series 1.5 grill - the one with the mesh - $80
all body panels/doors and bonnet - $50 each
Factory DIN pocket with flap - $30
Climate control unit - $40
Dash cluster - 185000 kms - $80
Front reo bar - $100
rear bar, black - $80
clutch master and slave cylinders - $50
brake booster - $50
aircon condenser and fan - $50
more to follow...
any chance of pics of radiator, 70mm fmic, and lock bar? does the fmic come with pipes?
Pics of HICAS bar and radiator, no pic of cooler but it's a generic 300x600xXX, no piping included, but it do have piping suited for a highmount turbo and FF plenum for additional cost
pics?
No pics of the actual gauges but they are the same ones as shown in link
http://justjap.com/store/home.php?cat=400
