  • Replies 104
What bits do you have left?
Maybe mark the sold items in original post..??
Cant edit original post, here's a quick rundown of whats still available:
Engine/Driveline stuff
RB25DET timing cover - $50
RB25DET polished cam covers - $200
RB25DET valley cover $40
Chromed igniter stand - $50
2 x A/C condensor fans - $50 each
Power steering pump - $80
PS rack - $150
Brake booster and master cyl - $100
Garrett GT3582R exhaust housing, .82 - $250
Jun "style" inlet manifold, still over $800 new on ebay - $600
BMI 86mm billet throttle body - $250
500ml surge tank - $50
KTS Intercooler, 600x300x100, 3" in and out - $200
FMIC, 600x300x70,3" in and out, BRAND NEW - $150
RB25det gearbox - was perfect previously was a bit clunky going into gear after i dragged it through the tunnel with the shifter in (only driven for 200 metres since), hence price - $1000
5Zigen 3" cat-back exhaust with oval muffler, quiet and was flowig 450rwhp - $250
Suspension/Brakes
Front strut bar, polished - $100
Electronics
Pioneer CD/MP3 headunit, basic model, black, removable face - $50
Jaycar response 4ch amp - $100
Fusion 12" sub in box- $50
Body & Interior
Garage Defend carbon fibre air guide, perfect fit for GTST, good condition - $400
Rear lights, black - $50
Series 2 rear wing, black, with boot - $100
Type M side skirts, good condition - $150
400R side skirts, 1 has a slight crack otherwise a really well made set of skirts, gunmetal - $150
Series 1 dash surround, very good condition, has been stripped and repainted - $100
Centre console with gear surround and ashtray, good condition, gear surround stripped and repainted - $10
Seatbelt stay, the swinging thing that holds the seatbelt off your neck - $40
Hey Mate, Do you have the drivers side window regulator and motor? if so how much? thanks
sold
this was a typo:
price is $100
Parting out a complete series 1 R33 GTST
Deatschwerks 740cc injectors (straight fit in factory rail) - $450 Will these 740 injectors fit the std. R32 GTR fuel rail? If so what`s your best price? Adam.
sold, and 25 injectors don't fit 26's
check above post for whats still available
hey mate,
do you have the cluster still? what sort of condition? did all the dials work properly?
Yes, clsuter is still available, perfect working order, approx 185000 kms on it
PM if interested
hey mate, me again still after the boot/spoiler.
looked it up and i believe the boot is interchangeable between the series 1 and 2. can you/anyone confirm this?
i will be able to pick it up either late Friday (5pm onwards....ish) or early Saturday morning (6am..ish) does that suit?
Are you sure it was me you contacted? I have no memory of it but anyway....
Yes, boots are interchangeable between series 1 and 2, this one came off a series 2 with wing attached.
PM re price and pick-up. You do realise I'm in QLD?
yea mate. It was just a post on the thread.
Im currently working in central QLD and will be heading through brisbane this weekend as the job finishing and im driving a company ute back from site to NSW.
Currently i have only 5 posts so i cant PM yet. Just PM me your email address or phone # to arrange pick up.
The diff still available?
diff sold
Parts still available:
plenum and tb - 800
series 1.5 steering wheel - 100
type M side skirts - 100
400R side skirts - 100
GT35 exh housing - 150
tail lights - 100
rear garnish - 40
gearbox - 800
tail shaft - 100
strut bar - 100
aircon fans x 2 - 50
front reo - 100
PS pump - 100
PS rack - 100
brake booster and master cyl - 100
alternator - 100
g/box xmember - 50
sill scuff plates - 40
power antenna - 50
climate control - 50
turbo heat shield - 25
timing cover - 50
valley cover - 25
cam covers - 200
igniter - 40
chromed igniter mount - 40
seat belt stay - 25
surge tank - 25
bonnet latch/stay - 40
boot and wing - 100
whats my chances of just getting the FMIC piping to suit a front facing plenum?
cheers
Edited by briggsey
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
