For what?
ECU loom is pretty much same same as R32 RB20DET. Stereo is Nissan Universal, there's a pic in the Cefiro Parts sticky.
The rest you gotta work out all by yourself, or get a workshop manual from Japan and learn to read Japanese. Theyre on ImportMonster all the time :)
https://www.sau.com.au/forums/topic/314163-cefiro-wiring/#findComment-5155919
  • 2 months later...
see if you can find an rb20e loom thats what i used when i put the 30e in mine.i think the injector plugs may be different,it was about 4 years ago tho i might be wrong there. it was deffinatly the 20e loom tho. i replaced the 20e with a 30e then ended up with a 25de 32 head and loom on it.
https://www.sau.com.au/forums/topic/314163-cefiro-wiring/#findComment-5277313
What about a ser 2 Rb25 into a cef thats had a Rb20det in it?
juz done mine bout 2 months ago.. ill try looking for the diagram but i dont like the chances... from memory u need to connect 6 wires and run 2 wires through to the engine bay. pretty easy upgrade.
https://www.sau.com.au/forums/topic/314163-cefiro-wiring/#findComment-5281065
