Hey Boys and Girls,
In the market for a new boost controller as I'm only running a GFB bleed valve at the moment.
Did a search through the form for what people think of various controllers and didnt really find alot of info.
So im just looking for what people have used and found to be good etc etc.
Car is 32 GTR, forged, bigger turbos, lost of boost etc etc.
Note:I'm running PFC with Z32 AFM to be added soon and would greatly prefer stay with the FC.
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/314165-boost-controller/
best controller to use to date (for me) is the AVCR.
have also seen excellent results from the greddy profec B spec 2 and blitz dual SBC.
personally think eboost2 is best at holding boost (from what ive seen)
and hate anything HKS (havent seen one work to a satisfactory standard yet professionally tuned or not)
FYI PFC boost control kit is similar to the AVCR for use.
GL
The ACV-R is not, it is older tech now by many years.
All you need to do is find a dual-stage solenoid one.
Anything like a Blitz Dual SBC, HKS EVC 4,5,6 - are all excellent choices in the dual solenoid department.
Like most things, totally comes down to whoever is setting it up understanding the finer details. Setting up a EBC isn't rocket science but sometimes people set the gain incorrectly and get poor boost curves and so on.
having extensively used EVC 3 4 5 and 6 I have to disagree and say they dont belong on that list.
cars i have seen them work well on were cars that could run actuator pressure faultlessly, and the only car ive seen run highboost successfully with an evc was an evo9 with a 1.5 bar actuator. funnily enough it was running....... 1.5 bar.
other cases were cars running mild boost ups that would run consistent boost levels off straight actuator pressure. anyone experiencing a pressure drop off the actuator could never tune it out with the evc, and thats professional tuners inclusive (no names).
to run big boost id be looking at a eboost2. i know of one running a flat 27psi from threshold to redline on a 15yo 10 pound actuator.
I have the PFC boost control kit, it does the job, doesnt spike, I havent had a problem with it
I do agree its probably older technology and theres better out there but if you want to keep your interior free of extra gauges, units whatever then the PFC Boost control kit is good cause you can just control it through your hand controller... if you dont have a handcontroller then yeh probably go with something else lol
Like i said - always comes down to whoever is setting it up most of the time.
I know 3 friends that ran them without issue. One currenty in a car now... works fine!
Most of the time, yes, but not when I'm working on it >_<
As for the eboost2, I cant honestly be totally sure as Ive only seen it in one car, but it was definitely most impressive. Yet reference some of the BIG drag cars with BIG boost and they also run the eboost2, so that's saying something. I don't mean 30 pounds either lol.
forget about solution mode, what do you want the boost controller to do?
if you just want a single fixed boost, then just skip everything and pick the most suitable sized actuator spring
no need for controllers, wires, etc etc, if you want to bleed more out / run 2 stage then go from there
I would like to be able to run 2 stage, have high low settings, i've heard some of the models can change boost settings in each gear >?
scramble boost is a pretty cool little trick but it isnt necessary.
Cant really fauly the Blitz SBC R for the price at the moment.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
