Hi all.
I have 2 cars. R32 gtst that I use mostly for track and an FG XR6 Turbo ute.
The reason I'm asking about increasing track is for 2 different reasons. Increasing front camber on the 32 and trying to get the wheels to fill the rear guards in the ute.
I'm planning on installing R33 lower control arms (longer by 15mm I believe) for my 32 and it will increase the front track. What I want to know is how much it will increase by and how much will it effect my handling? and in what way? more oversteer???
For my ute I want to use 30mm spacers for the rear to try and push the wheels out into the guards to make it look better (30mm each side). What will this do to the car? Will it be more prone to understeer???
So yeah. Comments and feedback on what experiences you guys have had with playing around with increasing track.
https://www.sau.com.au/forums/topic/314167-increasing-track/
You are better off going for wider rims to increase the track and throw in some upper adjustment to get the camber you need.
Changing the lower control arm length means you may end up with bump steer issues and need to change the tie rod length and location etc. I dont know to be honest, but suspect that unless you are in for the whole hog with testing, then with suspesion less is often more.
I want to mod lots of my suspension and have a few plams, to that i can drop the ride height whilst still having neat std geometry...lol but i reckon it will be a disaster and my car is destined to look like a pansy with its std ride height :)
Yeah.
I really wanna stick with 33 GTR rims (I have lots of them) and not sure if adjustable upper arms will give that much camber? I really don't want to widen track at all. Just at $50, 33 lca's seem like a cheap way of getting camber.
Have you considered roll centre adjusters? The longer ball joint things? From what I understand they allow a lowered car to maintain std geometry.
Have not played around with this on road cars, however the same principles apply to the Formula SAE vehicles I have worked on.
Essentially, the goal to maximizing the potential of the tyres to generate grip is to equally load (vertically) each tyre. In racing, the aim is to run as wider track as practically possible (or as the rules allow) in order to minimise weight transfer during cornering (known as lateral load transfer). This ensures that each tyre is evenly laden. In essence, what you are changing will generate more grip on that SPECIFIC axle, and hence will cause oversteer (if anything). Since it is the front, the tendency will be for the front to generate more grip. However, the change you are talking about (less than 30mm overall due to the inclination of the lower control arm) is small (30/1460 = 2.1% change in track) and I doubt a hugely noticeable effect will be felt. You could also achieve the same track change from running more negative offset in your rims (-15 less than what your current setup is).
The more noticeable effect will be the additional camber which is achievable which will help to generate heat in the tyre faster, whilst also providing more lateral force due to camber thrust. Alternatively, this will obviously wear tyres quicker aswell as well as potentially overheating the tyres (depending on how much negative camber you run).
You will also increase your King Pin Inclination (KPI), which will increase the amount of positive camber that will occur during any steering/cornering manoeuver. This is good for generating grip on the inside tyre, but detrimental for the outside tyre. Another problem is that KPI increases the 'jacking' forces seen during cornering, which generally cause the inside rear (and even front in some racing vehicles) to unload and in some cases lift of the ground. This is bad for utilising your tyres evenly.
As Roy stated, you may also end up with bump steer, although Im not entirely sure this would occur as you are simply increasing the length of the bottom pivot, rather than changing the angle it generates with the ground.
Take all this with a grain of salt so to speak...
If I were you, and your simply after camber, just get a good set of adjustable upper arms and be done with it.
Cheers,
David
Edited by R32Abuser
Thanks. that's good info. The increased grip on the specific axle is what I needed to know most.
Happy with the camber that should be achieved. About 3deg which should be fine. I still have whiteline adjustable bushes for a bit of adjustment.
You lost me with the KPI stuff though haha.
2.1% doesnt seem that much. If the oversteer is increased hopefully I can dial that out with swaybar adjustments.
I'm starting to think that I should wait for the next track day and pyro the tyres to see how much camber I really need.
i think i have gone just about as wide as you can go without using spacers on the front of my r32 gtst got r33 LCA's (10mm longer and give -2.5 deg camber at my ride hieght) , Kazama extra length tie rod ends with extra lock with bump steer adjusters on each end, s14 steering rack (bout 5mm longer each end) and run 17 x 9 +17 p1's with 235's on the front. I also have camber adj up top run total of -3.25 deg and castior running 7 deg. Running 27mm whiteline adj swaybars front n rear too front on medium
People told me everything from rims wouldnt fit in gaurds to that much increase in front track will tram line you... i use mainly for drift but do sprint series as well and can say that personally i think the handling for both is awesome can dial out most oversteer with sway bar adj and coiler damper adj
go wide ... go big :down:
im still in the build stage, but ive been playing so far with s14 rack and r33 lca's, i really dont have anything to report though so consider this post useless :down: but im going to keep one side competly stock, wheels and play around with the angles of the other side to get it to be all sweet.
no in all seriousness...
the boys at ns.com are chopping and rewelding extensions and strengthening their lca's.. i think one guy even has extended 30mm.. they are also drilling new holes in the crossmember and mounting the lcas higher..
could you possibly reinforce the end of the crossmember by boxing it in at the bottom, and drill a closer to the end and higher up than before??
now i know that sydney kid warns against r33 lca's, due to bump steer... but im wondering..
what if you extend everything out by... lets say 30mm... so you add 30mm to your top arm or fabricate a new top mount... or add a 30mm plate behind the original mount, 30mm to your lower arm and 30mm to your tie rod..
keep all the same alignment, but everything extended out 30mm.. then play from there... would that work?? you would have to mount the castor rod at its original angle by drilling new holes in the control arm.. but thats easy.
because everything is the same.. would you need rca's?? the longer arms at the same spring height will make the car higher, so youll need to lower it more, but it would be then no different to how it was before...
if you get rca's do you need to then do something with the top arm??
having said all that...
on one side i have a 17x9 +25 and on the other side i have a 17x8.5 +not sure but less than 20 and the 8.5 sits way more out than the 9 does.. and the 9 has an r33 lca and the 8.5 side has the original r32 lca.
hahah notice a mistake with the KPI...KPI affects the steer-camber characteristics of the car. That is, how turning the steering wheel causes the wheel to gain or lose camber. Its reasonably in depth, but overall the thing to keep in mind is that increasing KPI (more positive KPI) will cause both the wheels to gain greater amount of positive camber. Positive camber will help the inside tyre generate grip, whilst decreasing the grip generated by the outside.
In terms of bump steer, although I said that I couldnt see how it would cause greater amounts, I would only really know the answer when I would install the LCA. If Sydneykid has said it will cause bumpsteer...BELIEVE IT. He is a wealth of knowledge with more experience than 99.99% of members on this forum. If he has warned against them, dont use them if I were you.
just be careful with the ns parallels, they run strut fronts which are totally different to double wishbones.
i have a modified subframe with LCA about 2cm further out for about 2o more camber, and also 2cm more track. feels much better up front with reduced understeer
is that with r33 lcas or r32 lcas duncan??
yeh the ns.com boys have mac sturts... so it s a bit differnt, but still, it can be done..
how do bump steer adhjusators work>??
p.s. if im talking like fatz is because imj in a fatz like state.. my apologies.
32 LCAs.
bump steer adjusters - depends which ones and where. To me it's about protecting the carefully researched/developed factory geometery with a little more of what I want like lower and more camber. Thats why I run the wider LCA point instead of shorter upper arms, to keep it more like factory setup.
longer lower ball joints help give lower ride height but it is very difficult to do the same with the UCAs.
spacing the tie rod end down is probably more important in most cases but you would need to measure the bump steer fully to be sure you are in the right place for a given setup.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
