I have a na Rb30 block with vl turbo crank rods forged pistions and vl turbo head. fresh rebuild new bearings bottom end. vl turbo oil pump fitted, test 1 start first go no oil presure/ oil at all. Test 2 change oil pump to standard oil pump, check for leaks on suction side, no leaks. engine starts no oil presure/ oil. Have removed presure switch and oil filter to prime the pump and 2 see if any oil comes out. No oil. Dose anyone know if and what the difference are between a turbo crank and a Na crank. Please any info maybe helpful.
https://www.sau.com.au/forums/topic/314198-oil-pump-confusion/
only things different between an RB30E and an RB30ET are the pistons, oil pump and camshaft...everything else in the long engine is the same.
Thanks for that. I thought that was the case but thought i would ask cause the problem i have is how is it possible that a perfectly good working oil pump that i pulled straight off running engine filled with vaso for it to be primed does not pick up oil. Was thinkin that possibly the crank flats for the oil pump were closer to the block and would cause the pump to not turn. Any thoughts?
Word of warning - NEVER start a newly built engine unless you are certain you have oil pressure. Check for oil pressure by cranking only, with spark plugs removed.
I know this now but thanks for the Warning. It came straight of working engine so one would think it would work straight away but at least i know 4 next time.
Any help peoples
by vasso you mean vaseline? oil would be fine, crank it with no plugs in get pressure and off you go,maybe if you used vaseline i think its too thick,maybe vasso is somthing else, remove the plugs anyway and crank the engine some more-provided you put plenty oil on the bearings in the first place!
Thanx people for your coments.
Have found that the first time i fitted the oil pump i put only oil and no vaso in it and the second time 2 much vaso and the third time just the right amount. The old goldie locks and the three bears trick.
Working all good at this stage runs sweet as
Yes i mean vaseline. The first time a filled the pump with oil and it did not work and yes too much vaseline was 2 thick2 suck up oil but a small amount of vaseline and oil on gears worked straight away. Thanx
query;
in doing this, will only disconnecting the coil packs suffice (so there is no spark)?
The benefit of pulling the spark plugs is that the rod bearings arent subjected to cylinder compresion forces, without there being oil on the bearings. Your cylinder bores should also all have a tiny squirt of oil in them from when your builder built the engine. (believe it or not some builders assemble engines dry!)...
I have had success priming the pump by using an air compressor too. Its a bit involved, but does work a treat.
So... after you have removed your spark plugs and unplugged the CAS sensor you can do the following.
1. Unscrew your pressure sender and put in a 1/8th BSP barbed fitting, with a piece of clear plastic hose attached to it. (so you can watch for oil).
2. Block or link your cam cover vents, including the hose that normally goes to the intake. (one way valve).
3. Connect an air blower tool to the dip stick tube with some 8mm fuel hose.
4. Set your pressure reg on your air compressor to about 5-10 psi and slowly begin to presurise the block.
(this will force oil up the pickup and into the pump, through the block galleries and out your clear tube attached to your gauge port. It will take quite a while to come through too, so be patient.)
5. Once you see oil in the clear hose, stop with the air tool. Then crank the engine for a moment. You should see oil flow at the tube.
6. With that all done, put the pressure sender back in and unblock your cam cover vents etc.
7. Crank the engine again and you should see oil pressure within a few seconds. Keep in mind the pump has to fill the rest of the galleries in the block and this can take a moment. Filling the filter will help cut this time down.. If you then have oil pressure you can re-connect everything and start the engine.
If it is taking too long to get oil through the hose at step 5, you can crank the engine while pressurising the block. Just be prepare to stop the moment you see oil in the clear hose or you will make a mess.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
