Hey guys I've just about finished an rb25 swap in my friends s13 and now were stuck on something. The motor will crank/turn-over, but it wont start. It sounds like it has great compression but just isnt getting the vitals. I'm not sure if the ecu has power, which would explain everything, but I also dont hear the fuel pump even priming. There is a small blue plug on the lower harness that we could not match up to its pair, nor figure out what it is. I will go over all of the grounds again just to make sure but I'm almost positive that those are correct. Any help is appreciated, thanks guys, I've already used a ton of info from this site and it has been extremely useful.
altho by the sounds of it uv got some sort of electrical problem, the most common thing iv seen done by people doing conversions at home is put the fuel lines on the fuel rail the wrong way.... make sure the one with the fuel filter DOES NOT connect to the fuel rail end with the pressure reg....
as for ur problem, i would be tracking down the a wiring diagram and check all your powers to a the ecu, especiialy ignition wiring,
make sure he doesnt have an alarm or kill switch he forgot to tell u about.
we checked the fuel lines and they were wrong... hah my bad. we have the ecu power and ground skipping the relay and going to direct power and direct ground. were getting 12v at the ecu with a meter so we know its getting power. after trying to start it with the fuel lines going the correct way is still does the same thing, cranks, sounds good, but doesnt spudder or hicup or anything. just keeps cranking and thats about it. I guess the next thing would be to check spark... how much is the ignition tied into the coilpacks? Were about to go over the ignition wires again to bring them to a solid connection instead of trying to go through plugs and relays. Thanks for the response, so far so good!
ur ecu needs to be switched on to start with (so it should be getting 12v from the ign switch) then it looks for a ign signal from the Cam angle sensor.... if there is no signal from that (which is another thing to check) then the ecu will not fire the coilpacks.....
as u said, check if its getting spark, if it isnt, check the CAS circuit and the power for the ecu from ignition...
also wot ecu u using?
the ecu that we are using is just a stock rb25 5spd ecu. the ecu is also getting 12v to the power ports on the plug. and the fuel pump is also getting power now because it primes right before the car starts. when i reversed the fuel lines after trying to start it a couple times with them backwards, i did have fuel pressure built up in one of the hoses. so i know im getting fuel to the rail. i havent checked spark yet but that will be done tomorrow or the following day when i get the time. I'll check the ign power with a meter and the CAS. thanks for the help, ill keep you posted.
I am said friend putting the RB25 into my 240. I am currently re-doing the timing belt to see if this motor will crank...
As i was doing this my CAS bracket decided to break in half for no reason... it fell off while i was looking at the belt. Does anyone know where i can order a new bracket
nissan will have a new one, but ur better off getting one from someone on here in the forsale section
if its backfiring or poping thru the air filter then ur timing is out....
either the timing belt is out a tooth (or so) or the CAS is out (or faulty)
check that the 3 timing marks line up
  • 4 months later...
i am having the exact same problem, got spark and fuel, the timing marks all line up, put a screw driver on the piston when checking TDC the timing seems to look fine, the only weird thing is the normal position that the plug on the CAS sits at is no where near where it should be the plug and wires have to stretch right over turning the CAS clockwise 180 deg, when the cam timing marks are lined up which mark on the harmonic balancer should line up with the timing cover mark? my timing cover mark is pointing just right of the last timing mark on the balancer, thats if u spin it clockwise its the last mark.
sorry for bringing up old thread but i am having the exact same problem, got spark and fuel, the timing marks all line up, put a screw driver on the piston when checking TDC the timing seems to look fine, the only weird thing is the normal position that the plug on the CAS sits at is no where near where it should be the plug and wires have to stretch right over turning the CAS clockwise 180 deg, when the cam timing marks are lined up which mark on the harmonic balancer should line up with the timing cover mark? my timing cover mark is pointing just right of the last timing mark on the balancer, thats if u spin it clockwise its the last mark.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
