Hi All,
I have my car in the workshop at the moment and they rang to advise the Z32 afm's and my HKS racing induction filter system doesn't line up and that they need some kind of a sleeve or adaptor to suit make all the connections. My setup is the same as the BCNR33 when it comes to aftermarket parts and accessories and just need to know where I can source one, preferably in Brisbane or if in Sydney to courier for tomorrow.
I'm trying to contact some other tuning houses in the area to see if anyone has heard of these and if so where you would go to get them. If anyone knows what these are or where they can be sourced I would be so happy. Any help is appreciated and I've done loads of searches but can't find anywhere I can source these locally.
You need adaptors as Z32's do not bolt on... Nismo items are the only ones that do.
Any Z32 AFM adaptor will work, not sure where to source locally though.
Try Just Jap and similar large volume places, most likely they are your best bet.
I tried calling a couple Brisbane places, All jap and All Asian Imports and they both said they dont have any and sounded like they hadn't ever seen one before. I might speak the workshop to see if they can fabricate something if I can't find where to get these from.
its probably because the HKS kit assumes stock AFM and ducting, the stock AFM's are 65mm vs the Z32s which are 80mm
if you use the standard rubber intake piping you can apparently strech over the larger Z32 shell
but if you are using HKS plastic / metal intake etc then this is probably not an option
i know with the apexi power intake kit you have choice of 65mm or 80mm kit to suit GTR
  • 1 month later...
Im curious about this aswell...
Because either way ur forced to pay like close to a grand in AFMS.
nismo ones are 450 each NEW = $900
or u buy an apexi suction kit $550ish and 2x z32 or 2x rb25 afms for cheapish. Either way it sucks.
Do the stock pipes actually stretch over z32 afms?
Anyone done this? LOL.
