Rb25det Exedy Heavy Duty Cushion Button Clutch Done Less The 1000ks
If you squint hard enough those horrendous barracuda wheels look a bit like r33 GTR ones!
....that still needs to be retrofitted to take R134A also.
The Frenchy's kit linked above, will cost you about the same as factory Nissan. The difference with staying factory Nissan is, you'll end up with an inferior AC system.
50k for an auto series 2 now. Does have a battery so probably adds a bit.
@GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad. @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
