Guys, have bought an EVO so reluctantly the Skyline is up for sale:- PM if interested/heaps more pics available to genuine enquires (please no time wasters as I've had dickhead after dickhead on Carsales....i.e. "can I tow a boat with this car" to "will this car seat 8 people.....!?")
Details as follows:-
Gunmetal Grey
Engine:
RB26DETT built by JHH Engineering
Wiseco 86.5mm forged pistons
Total Seal gapless rings
Tomei adjustable cam gears
Tomei 1.2mm metal head gasket + full Tomei gasket kit
Tomei oil restrictor
Tomei type B valve springs (head match ported)
ARP head studs
ARP rod bolts
ACL Race series bearings
Gates timing belt (brand new)
HKS 264/272 9.6mm Type B Spec cams
HKS 2530 turbos (match ported + std manifold match ported)
HKS stainless dump pipes (match ported)
Sard 720cc injectors
AEM adjustable fuel pressure regulator
Permacool fuel cooler
Greddy twin entry fuel rail
ARE Surge tank, half inch lines, 2 x Bosch 044s + Walbro 550HP lift pump
PWR 45mm radiator
CES 3.5” mandrel exhaust + front pipes
ARE 90mm intercooler + custom stainless piping
Greddy Type R BOV
Splitfire coils
Nismo 65 degree thermostat
High Energy Custom 6.5 litre baffled sump
Petersen Catch can
Earls external oil cooler + braided lines
Electronics:
Haltech E11V2
Eboost EBC
Hurst line-lock kit
Intercooler water spray
Omori gauge consol – oil temp/pressure + water temp
Nismo EGT
Nismo 260kph dash
Razo turbo timer
Suspension:
Bilsten Shocks with matched Whiteline F&R springs (Sydneykid's kit)
Whiteline front & rear sway bars
Adjustable front camber/castor kit
4:11 GTR rear diff and axles
Custom 2 piece tailshaft by Driveline Services
Custom rear cradle bushes
Cusco front & rear strut braces
Wheels:
Xyphos (Japan) 2 piece 17” x 8.0 front 17” x 8.5 rear
328 mm DBA 5000 series slotted rotors (front)
Brand new RDA slotted rotor (rear)
UAS caliper brackets (front)
A1RM pads front & rear
Braided ADR approved brake and clutch lines
Other:
Nissan GTR aluminium bonnet, N1 lip + bonnet latch
Nissan GTR grill
Nissan Front bar
N1 front bar vents
Greddy radiator deflector
R33 RB25DET gearbox
C’s shortshifter
NPC 1000HP rated twin plate clutch + flywheel (recently rebuilt)
All fluids recently changed - car has easily run low 11's.
Modification plate also fitted by engineer.
https://www.sau.com.au/forums/topic/314300-1991-r32-gtst-4-door-16500/
  • 3 weeks later...
  • 1 month later...
