As the title suggests,
Just installed an Autometer Pro-Comp Ultra-Lite A/F guage in an R33 RB26. Wired: Red to Power, Black to Ground and Violet to ECU O2 Sensor connection (clear wire at pin 29)
As soon as the ignition is switched on the last green rich LED lights up and the light never moves from it at all, ever.
I can't find any troubleshooting or posts anywhere with same problems and an answer.
So...
Is it a wiring issue?
O2 Sensor issue?
Is my car just that rich?
Something else?
Thanks,
Choco.
https://www.sau.com.au/forums/topic/314331-airfuel-guage-troubleshooting/
First off, if your car's that rich, you'd have other problems, bad problems too. So rule that out...
Was the gauge designed for use with the stock narrow band sensors? i.e not specifically for a wideband sensor?
Double, triple check youve got the correct wire on the ECU, it sounds like you might've soldered on the wrong one.
Try this also: put a volt meter on the sensor's wiring, and have a look at the voltage when the car's running. with your hand, crack open the throttle slightly and see if they change, that will make sure your sensors are infact, working.
at a guess i'd say your O2 sensor is dead. with the car running put a multimeter on the O2 sensor signal wire and check to see if it bounces back and forward between 0-1v. if you getting a constant voltage say 0.9v, then you O2 sensor is dead and that explains the reading on your A/F gauge.
please be careful. you are trying to wire up a 02 guage to a narrow band 02 sensor (there are two on the GTR)
the issue with the narrrow band ones is they are slow and narrow and are really only useful at stoich 14.7 AFR
they are useless for anything else other than giving the stock ecu feeedback during closed loop
so whilst your issue seems fundamental (wiring or dead sensor) once fixed please dont use this to tune the car
its likely thre guage will just bounce around all over the place and never show anything meaningful that resembles AFRs or how it's tuned
Cheers will try the multimeter. No the gauge will not be used for tuning. Purely used as a guide if the car is leaning out and shows something needs further attention. I know they are not accurate but I figure something a little accurate is better than nothing.
Thanks for the concern anyway.
Cheers,
Allan
yeah it sounds like your o2 sensor is dead. new o2 sensor should give you a bit better fuel economy.
also the o2 sensor won't tell you if you are leaning out unless you are really leaning out badly. you could have your car tuned to the ideal AFR of aroung 12:1 and it will still say you are rich. you could be leaning out to around 13.5:1 and it will still say you are running rich. if they do tell you that you are running lean then you have more than likely have damage done as the car has to be running pretty darn lean before they will tell you that you are.
also it would be worth hooking it into the other o2 sensor to see if it is also dead
Cheers,
Allan
Sorry mate but AFR guages are a waste of money. They are not even "a little accurate".
It will never do anything other than have nice colours, honest truth.
If you want proper AFR read out, you need to install a wideband and get feedback that way.
You'll never stand a chance running of factory O2 Sensors, they were not designed for that and as soon as the move of stoich, they are useless - rendering any gauge a waste of time and money.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
