I've got an R31, and soonish I'll be dropping in a N/A RB30DE, I plan to use it for circut racing and a daily as well
I've been thinking of converting it to AWD using parts from an R32
Anyways, does anyone think that this would be possible or worth it?
feel free to share extra thoughts on it
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/
how fast do you want to spend?
Easiest way would probably be to weld in a 4wd front subframe, gtr or gts4. And the front upright knuckle thing, mod the tunnel to fit the transfer box.
You could probably keep the live rear axle if you could find the same ratio as the front diff you use.
Do a search on google for full race motorsports, they make turbo manifolds, The owner Geoff, has done a s14 with gtr running gear. I believe it was just a bit of cutting and welding, but the s14 is closer to the r32/33/34 chassis than the r31
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160585
The cost of converting the R31 to AWD will easily surpass the cost of an R32 GTS-4 maybe even an R32 GT-R.
If you need a 4 door R32 GTS4 could be a viable option.
But if your budget is huge - It will be definately different.
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160629
not worth it. will probably only be slower around a track with the poor old NA RB30 (even with a twin cam head) dragging around all that extra weight. Far better ways to spend that money if your goal is to make it faster on the track
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160921
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
