hi
ive got my bloody hicas light coming on after about 10 or so mins of driving on my R32 GTR
it has an aftermarket steering wheel, and the diagnosic test said this is the problem..
my question is how do i get to the steering angle sensor ? i know its behind the steering wheel but what does it look like?
anybody have photos or a step by step guide on how get to it?
also when i do get to it, what needs to be done to it, what do i clean? align ? etc
sorry about all the questions but its driving my crazy !!
thanks
https://www.sau.com.au/forums/topic/314341-steering-angle-sensor/
was it doing it before the aftermarket wheel? if your aftermarket steerng wheel is causing the problem, check that you have got a proper hicas boss kit.
i dont know if there's any maintenance you can do on the angle sensor. i guess check for dry solder joints on the circuit board, and maybe blow it out wih compressed air for good measure?
this is what mine looks like. from a S1 r33 with no airbag.
it sits behind the steering column shroud. easy to take out once you have the wheel and shroud off. just 4 screws and a plug
thanks mate !
i bought it with a nardi steering wheel, so i didnt touch it....i dont think it has a boss kit? arnt boss kits so you can remove ur steering wheel? the steering wheel is not removable its bolted on
i will sus it out anywayz, make sure everything is cleaned up
can you align the discs on the angle sensor? are they markings on the discs that i should take note of?
no you cant align it. the stock steering wheel, or an appropriate boss kit, will have holes in the back of it to accommodate the arms sticking out of the angle sensor. when you turn your wheel, the sensor turns with it.
thats how i understand it anyway.
also, yes you do have a boss kit. your nardi wheel is bolted to it with 6 bolts around the horn button. the boss kit is what attaches your wheel to your steering column.
  • 4 weeks later...
just read on previous posts that the hicas light will go on if the brake fluid is low on R32's ? i just realised mine is disconnected ?! where does it go, cant seem to find the place to plug it into !! so the connector is just hanging there ?
i think the brake fluid container has recently been changed, maybe for compliance?
what to do hmmmm
  • 6 years later...
thought i would revive an old thread. cant seem to find what i need to find searching.
im fitting a nardi wheel with a saas bosskit which has the holes to properly house the two plastic parts for the steering sensor.
the bosskit has 2 sets of universal holes for different wheels to adapt, for my wheel to align it is on a 30deg (ish) angle to the locators. this is easy to fix as i just turn the locator to suit keeping the wheel aligned with the spline.
will this cause issues with the steering sensor and hicas? does this need to be inline with the spline or does this just start locating electronically on start up in relation to where it started from?
  • 3 years later...
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
