Could be a stuffed wheel bearing. I'm in the process (quite literally as we speak) of replacing my front ones because of much the same problem.
Did you get the rear wheels alligned too? Remember these cars have four wheel steering...
ok i'll give it a try and keep you posted on results, got to find time...
Thanks for the help
spacers? not too sure, will find out, they are aftermarket wheels
They are new rims, will get back balanced too
Thanks
Edited by Rbsushi
how long were the tyres unbalanced for?
if the tyres have been run unbalanced for a while they wear in a way that, when rebalanced, they unbalance themselves again
urgh and by unbalanced i meant out of alignment, shouldn't post when tired
I got new tyres yesterday, balanced and aligned, front and back.
after 1 day my steering tremors are back @80km/h, I'm going to change caster and sway bar bushings, cause mine are stuffed and get aligned again and see how that goes.
Take a look if your bushings need to be done.
that should only affect it when you put the brakes on. i had a magna that kept warping the front rotors every few months after getting them machined. they were really really bad. even at 60kmh by the time you had gotten down to 50kmh the vibration would be shocking and by the time you stopped it was ridiculously bad, but it never affected how the car drove when you weren't touching the brakes. ended up getting new rotors and it didn't warp them anymore.
I too am going for the bush route now because I've replaced wheel bearings and alligned/balanced everything so I can only put it down to the other weak link in steering gear; bushes. Either that or the mob who did my alligning/balancing did a shit job.
I had to get mine balanced/aligned twice cos the first did indeed do a shit job, so don't take it back to the same place the 2nd time, likely they'll do a crap job still...
The only company that does good aligns seem to be Tyrepower and Beaurepairs from my experience.
I found out that my suspension is stuffed, crappy ones through pedders, new but now pretty much throw away, bad mistake, and all my bushes need changing. So off to fulcrum suspension, where I'll get some tein suspension, shocks etc; put in and replace the bushes with fulcrums polyutherine bushes.post-63012-1272202781_thumb.jpg
But now with the accident today, it's all been put on hold, man whats next.............
:P
Did the suspension contribute to not pulling up in time - out of interest?
Insurance job (even tho' it looks as if you'd be paying Excess)?
Hope the car is all good pretty soon!
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
