Don't make come over and whoop your ass!!!! I hate to be proven wrong so here: Try to spot my swirl marks in these pics then! (I promise car was filthy in every one of these shots except the one on the driveway where you can see it has been washed). REMEMBER!!!!!! Car was 2 years old in these pics, never ever detailed ever and full of scratches, dings and swirl marks. No photoshopping and tell me doesn't she look clean? SEE! SEE?! I do not lie.
Na na na na nah!
  • Replies 57
There should be a 56K WARNING on this thread.
swirls are microscopic scratches. The reason why theyshow up on dark coloured cars is because the sides of the scratches reflect light.
This is unoticable on light coloured cars because they reflect alot of the ligh themselves.
Roy is right. Having the right things can prevent swirl marks.
Have any of you tried this stuff??
autogeek_1772_16115586
I think the only way to get rid of them is if you buffed your car and used a medium cutting polish. I suppose brasso would work.
Also when you wash your car you shouldnt be rubbing in circles. You should be going the same way as the air travels over your car.
I just cut and polished my car on saturday... it took 5 hours and i didnt have time to do the wheels..
swirls are still there..
in pics my car looks awesome, no swirls. but in real life its a diff matter.
I think it depends alot on the quality of paint. My old car was mettalic black, i worked hard on it quite often, and there was no swirls. BUT then some drunk idiot crashed into me, and i had to get one side of the car resprayed. After that, one side had swirls, and the original paint didnt. so i guess the nissan factory paint isnt that swirl resistant.
Im with justin on the swirls issue, in pics usually u just cant see swirls.
I present to u two huge pics. sorry to all those 56k users :D
Both cars have LOTS of swirls. One black one red, u cant see swirls in either so :D
you bastards.
I *am* on 56k!
and Skyline_boy, in your second picture...there are no swirls.....but there *are* trees growing out of ur car :confused:
BUT....can anyone recommend a professional? You know, the sort of person I can abuse and sue if I'm not happy lol
lol that isnt my car, thats just the result of doing something properly. I dont like lexus that much.
Guide To Detailing Your Car 6.04MB
Another guide "BUFFING FOR BEGINNERS" - shows you what polishes to use, what pads to use, and how much cutting and heat they make. worth a read
Buffing for beginners
hmmm.. how much money is in this Car wash & detailing bussiness??
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
