I've been told 1:1, but i've also been told 0.94 & 0.914 for the front, and 0.703 for the rear. and mr Penske says only like axles are 1:1, so my IRS car can't be 1:1, but I measured it (multiple times) and got 1:1.
Edited by sav man
0.7??? Maybe for a semi trailing arm rear with the shock just over half way along.....are you sure Roger has the right model Skyline?
The shock is connect to the hub so hub moves 1mm, shock moves 1mm. Or a tiny bit more because of the angle it is on. So 1:1 sounds right to me.
that is ecsactly what i thought, i'm just triple checking with other skyline guru's before i get the valving done. SK told me a while ago that it was 1:1 as well.
if the shock is mounted on the hub/upright its 1:1 if it on a control arm its not. all skylines are on the hub. so all 1:1. just because they are not at the outside of the hub makes no differance.
rear is def 1:1. front is mounted on the upright so its 1:1 too :worship:
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
