im lookin and gettin a different diff i have a r32 skyline it has the stock lsd but is still cutting one wheel even now and then what diff would be best for a street car i want somethink that is almost locked but has a bit of play for turning sharp eg parking and somethink that isnt heeps loud if possaible
https://www.sau.com.au/forums/topic/314404-what-diff-is-best/
A good cheap way to have a tighter diff is retain the stock LSD, but 'shim' it up. By adding extra preload shims (which are around $10 each), the diff will be a lot tighter.
From factory you are supposed to have two 0.80mm shims inside the diff centre. So that's a total of 1.60mm of preload.
You can use this guide here to show exactly how to shim your diff.
http://www.skylinesaustralia.com/forums/Di...l=shimming+diff
There's a lot of discussion on what shims should be used, I ended up buying the shims from my local Nissan dealer. I ended up having 2.45mm of preload. It skipped the inside wheel pretty bad for about a week and then it loosened up just a tad. Still feels very firm is very predictable when driving or drifting.
Just have a read of that tutorial link and it may give you some ideas.
-Jimmy.
Edited by -Jimmy-
  • 3 weeks later...
I have a Nismo GT Pro 2-way.. harsh, clunky, noisy, super predictable. I love it :D
It's not for everyone though.
got the same one. I love it!! Even though people ask if my car is broken all the time when they hear it haha
Do you get mothers clutching their babies when you drive through carparks? lol
But yes, if you buy an aftermarket LSD, you just get the centre (my Nismo 2-way actually came with new halfshaft flanges, crown wheel bolts, gasket and some Nismo oil).
Because I was changing ratios when I put mine in, I sourced an S13 auto complete diff (in housing) and dropped that off along with my new centre to my diff guy. I then swapped the housing myself up at the workshop (so I still have my stock 4.3:1 geared diff/housing at home if needed in the future).
Edited by bubba
I have a Nismo GT Pro 2-way.. harsh, clunky, noisy, super predictable. I love it :cool:
I just fitted the Nismo GT Pro TT 1.5 way.
Clunky, yes but only when cold and at slow speeds around corners.
Wouldn't call it harsh, but certainly bites. I've left it on middle initial torque setting but probably should have turned it down to low for the break in.
Good thing about having an adjustable spring is, once the plates are worn , just crank up the spring a notch and off you go. Expect longer life out of it. Not many diffs have this feature.
After it's properly bed in, it's best to adjust the torque setting to suit your car and driving style.
Can't compare the difference between the viscous stock and this.
You just have a feeling of complete control as the car feels so tight.
Way more grip around corners even when wet, which surprised me. The car seems to track differently but seems to point exactly where you want it to.
Today on a quiet road, rolling slow, put it in 2nd, pressed in the clutch, booted it, dropped the clutch and she just kept straight until I ran out of road. Just a smooth wheel spin with no shudder. Could have let go of the wheel, but not very wise.
As bubba says 'super predictable'.
Absolutely love it. :D
as Jimmy said, if u swing a spaner. just drop the diff and shim it, i did it to the R200 i had in my Sil drift car, i put to of the biggest shims nissan sell in it. Made it a locker basicly. after 2 drift nights, it was free enough to not skip the inside wheel when driving round the pits at the track.
its the cheapest way out, if you want top shelf hear and to spend some cash... than go the nismo!
I got a tomei Trax advance. 2 way LSD
cluncks, chatters and likes to chew up rubber in tight corners. Not so good in carparks either, sreeches wheels and carries on. Can also be a bit of a handful in the wet too if your not on the ball, especially when boost comes in.
Bloody brilliant though, incredibly predictable and the grip is amazing!!! The difference between the stock VLSD and a proper 2 way is just huge! The predictability and grip is ten fold as good.
Its not for everyone and unless your prepared to put up with the harshness of a proper mech diff, dont get one.
Get a GTR diff. thats mech 2 way too, re-shim it with some smaller shims so as it doesnt feel "locked" and doesn't bite as hard. Best and cheapest option for a streeter id say. Bear in mind the gearing is different so the speedo will be out.
Can ask though, what are the reasons for wanting upgrade the diff? Does the car see much trackwork? Drift? etc.
One good reason for an upgrade is mine:
The stock viscous in the GTS-T isn't designed to cope with high horsepower, never mind the torque of the 3.0.
I was sideways more times than I can remember and it really gave me the sh>&%$.
Sometimes it would hold but the wheels would shudder on launch, other times the ass would flick out like a bitch. Happened really bad once at Oran Park, felt like i was going to flip over.
Having that unpredictability in the back of your head with 337 rwkw defeated the purpose of building the car.
GTR diffs are certainly a good option, however don't you have to replace the rear axles and wheel hubs to GTR also?
That'll all add up.
Got a GTR rear put in mine, yes the axles and half shafts need to be replaced, I got the whole rear replaced, was tightened up a bit but as it doubles as a streeter I didn't want it to tight, much better feel on the track with no spinning one wheel coming out of corners and very drivable on the street.
Cost around $1500 for the supply and install.
how long would you expect a shimed diff do last,
ive been told that if you change all the plates to nismo ones that it will take what ever you do to it.
i dont know if this is true or not the cost is $850 diff out, new plates, diff in drive away
yes or no
I cannot answer how longer re-shimming would last but the larger axles and shafts means they are not going to break to easy, GTR shafts look much stronger than the GTS-T ones that came out, so the extra supporting mods was why I went the whole diff swap as apposed to just the center.
Anyone got some info on this, circuit, drag stuff with grip tyres, see what happens when they are being used in high load applications.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
