They charge $1100+ for a tune because they're the only garage in Syd (or Aus as far as i know) that can actually flash oem v35 ecu's and adjust ignition, afr, rev limit, speed limit etc.
All the flash tuning software isn't cheap either. If they've got a Technosquare or Osiris or whatever and got the dealer package, it would have set them back a fair wedge.
My understanding is they have to remove the oem ecu, soak it in a solution to remove a chip, then replace or flash (or do something with it lol), pop it back on the pcb board, reinstall in car then chuck it on dyno and tune for your mods.
I've had my ECU reflashed with a Technosquare. All they had to do was plug the connector into the OBDII port, and fiddle around with the laptop to get the map onto the car.
Modern ECUs don't need any work on the hardware to update the firmware.
However, 20kw atw gain is damn optimistic.
Must be a downhill dyno, or they're talking about flywheel gains.
Instead of adding more power, why not clean up the handling? Sway bars are great bang-for buck mods.
Or give it a mild drop with some decent springs.
Will sway bars give me off the mark acceleration ? im not looking to go quick around the corners just a little bit extra off the take off
No. Swaybars should have no effect on launch. Only cornering.
If standing start is your primary concern, shift weight to the rear and soften the rear suspension out. FM platform cars aren't fantastic for launching thanks to the weight distribution and rear geometry. Do you find yourself axle tramping when you launch? Making use of what power you've got might work out better than chasing more power. Outright power only really matters once you're rolling.
Another option (if you can find it for a reasonably cheap price) is to get a VLSD, and/or a 3.7:1 or 3.9:1 final drive ratio. I'm not sure what diff you have, but I found my VLSD to work reasonably well. I rarely ever did "single tyre fryers" with mine, anyway.
I've got a 3.9:1 final drive in my current diff (compared to the 3.5:1 in the stock setup), and my in-gear acceleration is a lot stronger. There is a sacrifice in top speed, cruising RPM, and fuel economy though.
sounds interesting i will look into it . Thanks
So, the factory ecu IS retuneable?
If so, it makes things interesting: my SC kit doesn't come with a ecu. Wondering if the VQ30DET computer is tuneable: at least it can handle forced induction, but AFAIK only autos were hooked up to it, which could make things difficult if it's looking for transmission signals...
Sorry to hijack: I need to know what my best solution is, and there doesn't seem to be a definitive answer. Also, being on the Gold Coast doesn't help: at this stage, I believe I'm limited to a Matt Spry tuned Haltec.
I don't think you want to try retrofitting a VQ30DET ECU. There are a slew of tuning options and it comes down to personal preferences and also tuners in your state. Some possibilities....
- Haltech Interceptor
- Haltech Platinum 350Z
- HKS F-Con
- Greddy E-manage Ultimate
- TurboXS UTEC
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
