They charge $1100+ for a tune because they're the only garage in Syd (or Aus as far as i know) that can actually flash oem v35 ecu's and adjust ignition, afr, rev limit, speed limit etc.
All the flash tuning software isn't cheap either. If they've got a Technosquare or Osiris or whatever and got the dealer package, it would have set them back a fair wedge.
My understanding is they have to remove the oem ecu, soak it in a solution to remove a chip, then replace or flash (or do something with it lol), pop it back on the pcb board, reinstall in car then chuck it on dyno and tune for your mods.
I've had my ECU reflashed with a Technosquare. All they had to do was plug the connector into the OBDII port, and fiddle around with the laptop to get the map onto the car.
Modern ECUs don't need any work on the hardware to update the firmware.
However, 20kw atw gain is damn optimistic.
Must be a downhill dyno, or they're talking about flywheel gains.
Instead of adding more power, why not clean up the handling? Sway bars are great bang-for buck mods.
Or give it a mild drop with some decent springs.
Will sway bars give me off the mark acceleration ? im not looking to go quick around the corners just a little bit extra off the take off
No. Swaybars should have no effect on launch. Only cornering.
If standing start is your primary concern, shift weight to the rear and soften the rear suspension out. FM platform cars aren't fantastic for launching thanks to the weight distribution and rear geometry. Do you find yourself axle tramping when you launch? Making use of what power you've got might work out better than chasing more power. Outright power only really matters once you're rolling.
Another option (if you can find it for a reasonably cheap price) is to get a VLSD, and/or a 3.7:1 or 3.9:1 final drive ratio. I'm not sure what diff you have, but I found my VLSD to work reasonably well. I rarely ever did "single tyre fryers" with mine, anyway.
I've got a 3.9:1 final drive in my current diff (compared to the 3.5:1 in the stock setup), and my in-gear acceleration is a lot stronger. There is a sacrifice in top speed, cruising RPM, and fuel economy though.
sounds interesting i will look into it . Thanks
So, the factory ecu IS retuneable?
If so, it makes things interesting: my SC kit doesn't come with a ecu. Wondering if the VQ30DET computer is tuneable: at least it can handle forced induction, but AFAIK only autos were hooked up to it, which could make things difficult if it's looking for transmission signals...
Sorry to hijack: I need to know what my best solution is, and there doesn't seem to be a definitive answer. Also, being on the Gold Coast doesn't help: at this stage, I believe I'm limited to a Matt Spry tuned Haltec.
I don't think you want to try retrofitting a VQ30DET ECU. There are a slew of tuning options and it comes down to personal preferences and also tuners in your state. Some possibilities....
- Haltech Interceptor
- Haltech Platinum 350Z
- HKS F-Con
- Greddy E-manage Ultimate
- TurboXS UTEC
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
    • No ABS, no TCS, no airbags, no cruise control, no lane departure assist, no emergency brake assist, no orange lights in the mirrors (continuously annoying me in multi-lane traffic), no stupid rear view camera. I am the one responsible for where my car goes and how it does it.
    • Cheapest Jaycar one is only $65.
