Hi all, just recently stuffed the rear turbo on my GTR. Sounds like a helicopter now as soon as any boost is raised. I've rung a few Jap import places and most have said they're pretty hard things to find.
Anyone been in this situation before and what did you do? I'm thinking a new turbo setup might be the go but money's tight at the moment due to building a house. Any suggestions would be appreciated! :P
https://www.sau.com.au/forums/topic/31445-blown-turbo-on-gtr-any-advice/
This happened to me back in September. If it happened a week ealier, I couldve sold you my one working stock turbo, but its already been sold, sorry :P
From when I was pricing around I was quoted around the $800 mark per turbo to just rebuild and steel wheel the turbos (not highflow and no ball bearing). Rebuild, steel wheel and ball bearing to N1 specs was $2200 per turbo at GCG (ouch!).
In the end I got a set of second hand HKS GT2530's that were rebuilt in Japan by HKS (not rebuilt to Garret specs). Id say to save some pennys and either go replacements like the HKS ones, or rebuild + high flow + bb your standard ones.
Thanks heaps guys. Clint32, once I get the turbos off and get them sussed out I'll PM you.
We're organising a Group buy of Garret Turbos.. the prices are awesome, & haven't yet seen them cheaper anywhere else. Let me know, as we're trying to have the order put in by late jan, early feb.
here's the link, http://www.skylinesaustralia.com/forums/sh...ead.php?t=30086
I had been running 15PSI since I got the car, occasionally putting it up to 16PSI for the drags and cruises etc.
New years eve we went for a strap on an island with long straights on a private road getting it up to the 240km/h mark in fourth gear. Everything was fine until I slowed down then went to accelerate and I just thought what the f*ck is that noise....... worst thing I've ever heard. :(
We had to drive home about 100km at 50km/h (otherwise boost would cause that horrible helicopter sound), was quite strange having people overtake you like you don't know how to drive a GT-R or something. ;)
BTW, my car's only just done 70,000km now. And I'm pretty sure they're original km's coz everything's immaculate inside (and out). So don't be tempted to wind that boost up!
You were lucky that the turbo lasted as long as it did - stock R32 GTR turbos should not be run any higher than 14psi from what I have been told.
You can run higher boost on a stock motor (presently running around 20psi) but depending on the condition of the motor & quality of your tune it is also getting into the danger zone.
Thanks for the advice guys, I'm actually thinking of going to a single turbo depending on cost. I'd love 2530's or T51's but if I can get good response from a single then it's going to save me money in hardware.
Anyone converted from twin to single? Would you recommend it?
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
