im selling my 95 r33 due to buying a Gtr r32, car is very clean its got 140,964 km one the clock, it runs well n pritty much standard never boosted, so its a good daily or project car to build from stock.
Price: $8,500 neg
kms: 140,964
listings mods:
- aftermarket front bar, side skirts, rear pods
- cat back exhaust
- turbo timer
- 19 inch konig unknown golds,, 9.5in at the rears n 8.5in at the front
- aftermarket front mount intercooler
- lowered springs.
- heavy duty clutch
- short shifter kit
so car looks nice ill send pics to interested buyers until i can post up pics soon
contact: 0411520000, call anytime business hours n after hours.
https://www.sau.com.au/forums/topic/314500-skyline-r33-gtst-series-15-95-model/
yeh cuz sorry i lost my password so used yours it was easy to remeber, well dosent matter wat user name u use to sell the car, people im still negotiable so make an offer or come see the cra.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
