Hi guys,
A few quick questions. I've been thinking lately about my RB25 and the oil it runs. Now the old owner always ran 10w40 magnatec (yup cheap stuff!), but being said, its run that for 5+ years and everything seems to be going fine! Considering its a 96 model motor, I dont believe a semi synthetic would be an issue for it at all. Being $30 bucks a bottle, I can do 3 times the amount of oil changes in the same period as say, a bottle of royal purple fully syn oil.
However, I then started thinking about what it best for the turbo. It runs a HKS GT-RS turbo, obviously somewhat 'new' technology. That made me think maybe the bearings in the turbo are better suited to a fully syn oil, as opposed to a semi.
Anyway, I was wondering whether anyone has thought about this dilemma before, ie older model engine with far newer model turbo.
What would you guys recommend? Does anyone believe it would be detrimental to the HKS turbo running semi syn oil (I mean after all its just a b/b turbo like came standard on the R33 i guess?)
There are many types/specs of Magnatec. What you and the previous owner have been using is most likely synthetic fortified or modified, and not a bad lubricant. The main thing is that whatever slippery stuff is in your sump continues to do its job for the required service life you expect from it. For extreme duty use, and/or longer service intervals the full synthetic is good stuff and cost justified.
If you service frequently, continue as-is and keep your oil spec the same.
Just to clarify, R33s didn't come out standard with a bb turbo...
As for oil, personally I would use full synthetic. Its not much dearer. Castrol Edge can be had for as little as $50-$55
At the end of the day but the choice is yours....
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
