Just bled the brakes on my R34GTT , all good, pedal as hard as nuts till I start the engine then the pedal gets a softish feel at the top of its travel.
The brakes work fine.
WTF am I doing wrong ?
It's not as though I've never bled brakes before and this is shitting me no end I've bled the farkers out twice just to be sure I had it right the first time.
Any ideas anyone.
:cool:
The only diff with the engine on is that the booster is helping put force on the master cylinder. So nothing will change in the hydraulics. Are you saying its worse than before you bled them?
To be honest I have found the procedure in the 32 GTR manual to be not as effective as a different method - how are you bleeding them?
I suffered from a lot of ineffective travel at the start of pedal in, brakes still worked fine.
Rather than pulsing the brakes with the bleeder screw open as the manual says to do, I get my assistant to push and hold the brake pedal hard while I quickly open and close the bleeder screw. Do this until no bubbles come out before moving on to the next, make sure you bleed in the right order - RR, RL, FR, FL and dont forget the ABS in the right order.
My pedal is now quite solid since switching to this method.
  • 2 years later...
Right, just going to bump this thread as I'm currently experiencing the same issue. I have bled my brakes twice and have got clear fluid coming out at all four corners with no air bubbles. Peddal is solid when the engine is off, but as soon as you fire up the engine the pedal goes to the floor. Mick_o mentioned he had the same issue when he fitted Alcon calipers to his car, and it turned out to be the ABS unit needing to be bled. This makes sense in my case, as I had to remove the brake lines from the BMC when I was removing my head, so air would have got into the lines before the ABS unit.
Now what I want to know, is can I bleed the ABS module without the service tool to cycle it? Mick said he bled his in the same way as normal, by cracking the lines off and pumping until no air came out. But his is an R33, are R34's the same? Another method I have heard is to take the car for a drive and keep hitting the brakes hard to activate the ABS, then re-bleed everything? I'm not too keen on that method for obvious safety reasons. Any other ideas?
Also, is it necessary to follow the 'procedure' for bleeding brakes? Ie. RR, RL, FR, FL? I did mine the opposite way, RL, RR, FR, FL; will that not work properly?
bleed all brakes on all cars from longest brake line to shortest, have you tried bleeding the brakes with the engine running so the abs is active and solinoids are open?
Yes, no luck. It just stays spongy. I think I'll give it a go just bleeding it as Mick has done, worst case it just doesn't work.
Mick, did you bleed the lines from the BMC in any specific order? I'm not sure how the ABS module looks internally, so not sure whether it's better to bleed one line before another or all at the same time, etc. etc?
Sometimes you can get a bubble stuck behind the piston, connect a clear tube to the bleed nipple and tie it up so it remains in a vertical position, loosen the nipple and then push back the piston, you will see a bubble or two rise up the tube, close the nipple and rinse and repeat.
But that wouldn't explain why it only does it with the engine running.
. etc?
No specific order Marty pretty sure I only cracked the 1 line going into the unit and yeah I done the abs last
if there is only a small amount of it might only be able to be felt when the booster is operating..? Bleeding brakes the oldfashioned way is a little risky, pushing the master cylinder piston all the way in past the point where it normally sits can cause the seal to leak.
air or seal damage....
air in the abs???
I found multiple issues on mine after a caliper upgrade and new rotors.
1. Calipers put on wrong side/upside down.
2. Bleeding order wasn't followed. -> Furthest away to closest.
3. ABS unit wasn't bled !!
4. BMS Stopper to remove the brake pedal travel from flexing fire wall
5. Stone gaurds getting in the way
6. Brake bias adjusted
Hope this helps
ACT Brakes :verymad:
and I took it to get a power bleeder on the job
My guess is booster. I've experienced similar troubles the whole time I've owned my current car. I've bled and re-bled the system, had it power bled, replaced lines, replaced and rebuilt all calipers, and replaced the master cylinder with no noticeable effect.
It wasn't until I borrowed a booster canister off a mate's GTR that they started working properly.
I've now replaced the booster, haven't had the opportunity to even start it yet to see if it's made any difference yet...
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
