Just bled the brakes on my R34GTT , all good, pedal as hard as nuts till I start the engine then the pedal gets a softish feel at the top of its travel.
The brakes work fine.
WTF am I doing wrong ?
It's not as though I've never bled brakes before and this is shitting me no end I've bled the farkers out twice just to be sure I had it right the first time.
Any ideas anyone.
:cool:
The only diff with the engine on is that the booster is helping put force on the master cylinder. So nothing will change in the hydraulics. Are you saying its worse than before you bled them?
To be honest I have found the procedure in the 32 GTR manual to be not as effective as a different method - how are you bleeding them?
I suffered from a lot of ineffective travel at the start of pedal in, brakes still worked fine.
Rather than pulsing the brakes with the bleeder screw open as the manual says to do, I get my assistant to push and hold the brake pedal hard while I quickly open and close the bleeder screw. Do this until no bubbles come out before moving on to the next, make sure you bleed in the right order - RR, RL, FR, FL and dont forget the ABS in the right order.
My pedal is now quite solid since switching to this method.
  • 2 years later...
Right, just going to bump this thread as I'm currently experiencing the same issue. I have bled my brakes twice and have got clear fluid coming out at all four corners with no air bubbles. Peddal is solid when the engine is off, but as soon as you fire up the engine the pedal goes to the floor. Mick_o mentioned he had the same issue when he fitted Alcon calipers to his car, and it turned out to be the ABS unit needing to be bled. This makes sense in my case, as I had to remove the brake lines from the BMC when I was removing my head, so air would have got into the lines before the ABS unit.
Now what I want to know, is can I bleed the ABS module without the service tool to cycle it? Mick said he bled his in the same way as normal, by cracking the lines off and pumping until no air came out. But his is an R33, are R34's the same? Another method I have heard is to take the car for a drive and keep hitting the brakes hard to activate the ABS, then re-bleed everything? I'm not too keen on that method for obvious safety reasons. Any other ideas?
Also, is it necessary to follow the 'procedure' for bleeding brakes? Ie. RR, RL, FR, FL? I did mine the opposite way, RL, RR, FR, FL; will that not work properly?
bleed all brakes on all cars from longest brake line to shortest, have you tried bleeding the brakes with the engine running so the abs is active and solinoids are open?
Yes, no luck. It just stays spongy. I think I'll give it a go just bleeding it as Mick has done, worst case it just doesn't work.
Mick, did you bleed the lines from the BMC in any specific order? I'm not sure how the ABS module looks internally, so not sure whether it's better to bleed one line before another or all at the same time, etc. etc?
Sometimes you can get a bubble stuck behind the piston, connect a clear tube to the bleed nipple and tie it up so it remains in a vertical position, loosen the nipple and then push back the piston, you will see a bubble or two rise up the tube, close the nipple and rinse and repeat.
But that wouldn't explain why it only does it with the engine running.
. etc?
No specific order Marty pretty sure I only cracked the 1 line going into the unit and yeah I done the abs last
if there is only a small amount of it might only be able to be felt when the booster is operating..? Bleeding brakes the oldfashioned way is a little risky, pushing the master cylinder piston all the way in past the point where it normally sits can cause the seal to leak.
air or seal damage....
air in the abs???
I found multiple issues on mine after a caliper upgrade and new rotors.
1. Calipers put on wrong side/upside down.
2. Bleeding order wasn't followed. -> Furthest away to closest.
3. ABS unit wasn't bled !!
4. BMS Stopper to remove the brake pedal travel from flexing fire wall
5. Stone gaurds getting in the way
6. Brake bias adjusted
Hope this helps
ACT Brakes :verymad:
and I took it to get a power bleeder on the job
My guess is booster. I've experienced similar troubles the whole time I've owned my current car. I've bled and re-bled the system, had it power bled, replaced lines, replaced and rebuilt all calipers, and replaced the master cylinder with no noticeable effect.
It wasn't until I borrowed a booster canister off a mate's GTR that they started working properly.
I've now replaced the booster, haven't had the opportunity to even start it yet to see if it's made any difference yet...
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
