  • Replies 48
Ye, mine is hand made, mufflers and all - super custom...
Either way forget the 3" people... he needs 3.5-4" given the power/turbo's he has.
Just go down to any reputable exhaust place near you... or whoever put your car together (im sure they know someone).
Tell them quite simply that you want:
- 3.5" or 4" exhaust
- Twin mufflers.
- Mufflers must be straight through, and must be as big as can possibly fit.
- No big cannon tips. If the rear muffler is 3.5", 3.5" tip etc.
You'll then have a much quieter exhaust than you do now - for about the same cost once you sell off the old exhaust.
There is no issue using restrictors, just control your right foot. It's really not that hard.
I drove around with a restrictor in for 8 months, never took the car past 50% throttle and 3500rpm.
- Twin mufflers.
thank you mate.
I know I can't control my foot, its hard for me sometime:) I think I better leave the silencer, I don't want make any damage.
do you know HKS SUPER TURBO MUFFLER? on HKS website they rate it 600hp. because I will keep small twin turbo setup forever, so no way pass 600hp.
if this catback not suit for me, I will find some good exhaust shop to made one.:P
The theory of "blocking your nose and see how hard you can blow" may not apply to an exhaust silencer :P
I ran one for like a year on my old S15 that was fairly modified, caned it senseless on a daily basis and it did no damage.
No your dilemma though. I got a 3" Nismo catback on mine, sooo quiet at lower revs, but may need to to go 3.5" and i still want quiet..
Hi everyone, i have full exhaust system, HKS dump and front pipe, trust 94mm catback, it is just too loud for everyday drive. my car made 340KW on 1.45bar, 280KW on 1bar, if I use silencer and low boost, drive it hard, will it damage the engine (maybe too much back pressure)?? i can hear the noise of air resistance when full boost (1bar) over 5k or 6k rpm.
I tried many exhaust shop, only 2 option to quiet my exhaust: 1 is change a small system, 2 is put the silencer in.
anyone give some idea??? i don't want damage the engine by using a silencer:(
thanks!
100% will damage it. if you drive it hard.
I understand it will damage if drive it very hard. but i mean foot down occasionally and on low boost which is about 14psi. not like drag race, or quick ran on mountain.
but anywhy i need a new system:)
My 2c, if your on a budget and cant replace exhaust at moment, get the apexi ecv but with 95mm internal diameter. its not the flange type, its the pipe one. My car makes over 600rwkw and the thing hasnt broken yet and it does make a difference. \
Over 600Rwkw?!!!!!! got any pics??? i wanna see this beast mate!
mate you have 600rwkw with a ecv? how big your pipe is?
can you go full throttle with ecv??
Edited by Nosure
have you guys actually tried to hit boost with a big turbocharger and a restricted exhaust?
The turbo wont even spool up when i had my exhaust restricted. Not sure about other cars though
yes mate, that what I thought. but my car is easy go up tp 14psi with a silencer. I never tried 20psi.
PS: my turbo is not that big:) only 2 baby t517z
Edited by Nosure
I just bought a apexi ecv 95mm pipe type.
hope this will work, and no resistance when its open.
:thumbsup:
thank god at last sombody not just talking shit on the internet! another clasic full of shit thread thanks lads! i agree with guilt toy by the way,unless its like a 1 inch exhaust you may meld somthing due to heat restriction!
Edited by aerofocker
maybe you got a external wastegate??
i think the actuator type's turbo will still spool up fine with restricted exhaust.
Edited by Nosure
If you put a silencer in, you are effectively making the exhaust what, 2" maybe less? (depending on outlet size).
If you then intend to even ATTEMPT to put your foot down you are going to do some severe overall damage without question.
That much backpressure with turbo's that flow that much is never going to end pretty
tell me about this severe overall damage? the car will be laggy and lose loads of power all over the range and retain heat in the general exhaust area fair enough.
I want to know what dammage you speak of?
You don't just get heat in the exhaust area, there will be excessive heat everywhere...
Try it and see, you can cook the motor. There will be heaps of extra heat in the head, warped head? blown head gaskets? valve issues?
Hell get it too hot and then you can also cause detonation and we all know what happens next.
Your turn.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
