I'm just curious regarding the new laws on cars being manditory fitted with ESC. Will this effect importing a car?
EG, if i import a R33 with no ESC, then try register and comply it in vic in 2012 after the laws are in full effect will it need to be fitted with the new parts, if thats even possible to do?
"the new law requires all passenger vehicles and SUVs made (or first affixed with a compliance plate) on or after January 1, 2011, to be fitted with a compliant ESC system"
http
:cool:/www.goauto.com.au/mellor/mellor.nsf...25764D0007B2E8
I am quite confused...cheers
Vehicles on the SEVS register are exempt (ie skylines). Probably because they have to comply with ADR's in order to be complianced, and are signed off on already.
even brand new cars get complianced.... hence "first fitted with complaince plates" .. i would say its just brand news cars ... but good question, i would be interested to see what other people have to say about this
I'm gonna say no on the fact of that I'm pretty sure cars only have to comply with the ADR's / laws in the year of manufacture or something like that.
Eg. I don't think you're going to have to fit ESC to a 60's Mustang you import. And the same with cars that don't require cats or seat belts.
i think i heard or saw somewhere that its only new cars have to have it, for example once it takes effect and becomes mandatory than all cars made after that needs ESC but anything before is fine.
Moving forward - what about for imports manufactured after 01/01/2011 - I'd imagine not all of them would have ESC
most of the import models manufactured after 2011 come with ESC already. its only the shit spec ones that don't.
mate's dad imported a '69 mustang a couple of years ago. speedo in mph, 110db exhaust etc, but it gets away with it cos it's a 'classic'. it'd be a nightmare to impose such regulations retrospectively.
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
