as title states, i have a set of SSR Strusse wheels for sale, have freshly powder coated black centres, huge dish and would look insane on a stagea. follow link for pics and contact info
http://www.skylinesaustralia.com/forums/Sa...ml#entry5153488
https://www.sau.com.au/forums/topic/314533-ssr-strusse-19x10-19-19x11-11/
would look insane on a stagea.. if they would fit.
you won't get an 11+11 on the rear without a spacer to clear the struts, then you'd need wider guards to cover them
Not to
mention as soon as u drove atessa wd flip out!
why? just make sure you get the right tyre sizes to maintain the same rolling diameter front and back.
yeah people put different size tyres on the front and rear of stageas and awd skylines all the time, sure its not reccomended but its not like they have a locked centre diff. and im pretty sure they will fit, my quick offset maths says they will. but of course if someones interested id reccomend a test fitment first
what? no.
you have to maintain the same rolling diameter front and back or your ATESSA. This means the diameter of your wheels plus the tyres in the front have to be the same as the diameter of your wheels plus the tyres in the back. Tyre profiles are measured in percentages of their width, so when you run staggered widths, you have to make sure the profiles are still the same size.
use this to help you choose:
http://www.miata.net/garage/tirecalc.html
It is doable on a Stag with those wheels.
235/35/19 front and 275/30/19 rear and the rolling heights will be the closest you can get for staggered 19s. from memory, they're only 3mm apart
D.
currently has 245 35 19 and 275 30 19
  • 1 month later...
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
