Hello Everyone,
just thought I would share my experience with ACPT carbon tail shaft. I see there is a Thread that goes way back about them as well. I bought a High HP one from them in December, was in the car a GTR R34 for 2 weeks then is sheared of at the yoke... I rang them they supplied another one, put it into the car and the balance was that bad I couldn't drive the car... I have since spent another $700 to get it balanced, the front uni was in back to front, the weights were out that much it was a joke. It was suppose to be Dynamically balanced in the good old US.
I rang them and spoke to them about it and they didnt want to know about it... If I have more trouble it will go into making stubbie coolers...
My recommendation is never buy one of ACPT drive shafts, If I had of known before I would have bought the PST carbon shaft, they are a lot better...
Dont not get one...
Regards Dave
https://www.sau.com.au/forums/topic/314553-acpt-carbon-drive-shaft-problems/
Did anyone get there shaft in and have no drama.
Mines sitting in storage shed in Japan as havent decided what to do with it.
Thought I'd put it on Yahoo japan as a giant dildo
Atleast someone would get some enjoyment out of it. All its caused is headaches for me! haha
  • 3 weeks later...
ithought it had been proven many times before that carbon shafts are unreliable and break more often than the factory items nearly all the fastest gtrs in aus run factory shafts what a waste of huge amounts of money better spent elsewhere
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
