Adm Cars Have Usb Socket Behind Cluster Panel...
I was told by someone working at a Nissan Dealer that when he had the instrument panel disassembled on an ADM car he saw a USB socket in the loom. It just wasnt mounted on the cluster panel. Has anyone investigated this? If its non operational I wont bother digging it out but if it serves functions such as allowing us play music or update the gracenote database I will make the effort to pull my instrument panel apart and leave it accessible.
I have never seen it. done a few ADMs and most of what I have found on teh net tends to be hearsay when actually tearing one down. feel free to prove me wrong though.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
