Okay. Actual full size replica of the Titanic. 25 million dollar building in my home town area. =)
I visited it and the Liverpool Legends were there (Endorsed by Louise Harrison - George Harrison's sister) which is the best cover band for The Beatles.
So here are some (very few) pictures that I have from that. I will be putting more up when I get a chance.
And if you want terrible lighting, go to a concert of some sort... lol
What's cool is that they have ACTUAL stuff from the Titanic, and people come about who were relatives from the actual crew etc. They also have a 100% authentic 1 million $ replica of the staircase from the Titanic. Talk about an amazing place, this thing is neat as hell. Thought you guys would love it, too bad it didn't make it for real =(
Edited by AKW
  • Replies 200
Yes, you can ACTUALLY see what it WAS like to be ON the Titanic...
http://www.titanicpigeonforge.com/
Something else amazing is... if you DO come here to see that, ever. Your tickets would cost you 22.0893 AUD per adult. Which is AMAZING.
Edited by AKW
I took these two shots (amongst others) the other day while I was at my cousin's house for Easter lunch and dinner.
Unfortunately, I didn't think to clean the chrome-backed mirror of my cousin's Prado before taking these shots, and I'd forgotten how much extra detail you get with a D-SLR. I'm not yet nearly good enough to go thru it with Photoshop to clone out all the blemishes, so all I've done for these is some exposure, saturation and cropping adjustments.
It adds the lines to the viewfinder that split your image into 9 squares, they don't look emulated, they look like they are really there. they dont look any different to the focus points and horizon lines that are there already.
Look in your advanced options and see if you can find it.
ohh yeah the rule of thirds assist. This viewfinder lens replacement assists you in figuring out what's in focus, and what's not, and if in fact something really is in focus (line up the 45 degree split on the subject image and it'll be in focus). The oldschool film SLR's used to use this trick. It doesn't affect liveview.
Call me old fashioned, but I hate liveview unless I'm shooting something from ground level. The day someone makes a gooseneck adapter for the viewfinder I'll be all over it.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
