ill definelty try that, i was playing around with different settings but i dont think i used that one will post up pics when i try it :)
Hmm, the Exif data says that the flash was fired for that first shot.
If you're using Firefox, try this program and take notes of what settings people are using for various photos: https://addons.mozilla.org/en-US/firefox/addon/5673. It doesn't work on all photos, but it should help you out.
  • Replies 200
The last shot is great. Would love to see a bigger pic of it.
Agree with Sid - would love to see bigger versions.
CPL you say? Gotta check that out, being car obsessed and all.
CPL = Circular Polarising Filter
And I can't comment if it would actually make car shots better
IMO awesome car shots DO have reflections.
Trick is to not have crappy stuff IN the reflections lol
Facebook l Redbubble l Twitter l
© Copyright All rights reserved Aaron Radford 2010
Here is a Larger version
Strobist Setup
Canon 430exII @ 1/2 power on light stand approx 6ft camera right shooting down onto models back.
Erm... CPL DOES cut out the reflections.
As you rotate it lets in light from different angles, so you can twist to let some reflections in, and glare out, or twist to remove reflections and let glare in. It Imagine all the light coming to you is made up of 3 sine waves moving sideways like slinkys. one is horizontal, one is vertical, one is 45" between. The CPL removes the light from ONE of these directions, changing as you rotate it. Wow I sound like professor frink! WHOOO HAveNNNNNN and the MOnkeys!!!
I'll post up an example when i get home. I have a few test shots from the same angle to show the difference. :/
This is how you can imagine it works - look at the second picture here: http://en.wikipedia.org/wiki/Polarizer
Basically lots of light coming from all directions - CPL cuts it out and only lets light from a certain direction come through. Rotating it changes this direction.
(direction might not be the best word here but you get the idea)
Back in April 2008 when I bought my first CPL I got it for better colours and cool looking sky's
Here are four sample pics I took (None of them have any PP done)
well the way I thought it worked was as glare being diffracted light and reflections being reflected light, and a polarizer will only permit light in one plane to enter the lens. So my assumption is that a CPL will remove glare, but will only remove the intensity of a reflection, but not completely.
if your polariser is letting in the reflection of a hot chick next to the car, that's a good reflection.
if your polariser is letting in the refection of extra light from the sun you don't want, that's glare!
You know what i mean anwyay :)
You need a little more exposure and post processing on that one. You didn't get anything but the highlights on the car. You're having trouble adjusting for brights to darks.
Try and equal your shot out by the EV reading on the camera compare night and point it at the car and see what the white equals and adjust for the best of both which should be in the middle of both.
Does that make sense to you?
EDIT
Looks like you shot in Auto mode as well, you need to shoot in M (manual) mode and mess around with your EV and Aperture. There are some nice guides here on the forums in this section. As well, you should never let your camera get to 1600 ISO unless it is something you just can not capture any other way. Get grain real bad at those levels.
Edited by AKW
Not sure what Ev is either, but on my Cannon (unsure about Nikons) Tv is Time Variable, meaning you can put it on a tripod and use a longer exposure. Also, try adjusting the white balance to get the colours right.
Btw, your car looks great now. Maybe some clear indicators and some work Meisters would look AWESOME on that thing! Possibly a front mount as well :)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
