Available:
Update! 26/5/2004
Pictures HERE (click)
These parts are available. If it is not listed here then it has been sold or is not available. Please do not ask for parts that are not listed here or I will give you a ridiculously high price and after you've paid for it, I'll go to a wrecker and buy it really cheap and send it to you.
phorj now has all of the parts, please PM him with enquiries:
http://www.skylinesaustralia.com/forums/pr...do=newpm&u=1333
KYB Gear Climb struts. RS*R springs $300 ono for the front pair
Quarter Panel black (click) $150 each
Steering rack $100
K-frame $75
Power steering pump $40
or rack, K-frame and pump for $150 together
Manual pedals set $150
Clutch master cylinder $30
Steering column with 2 keys $20
Brake Master Cylinder & booster $80
HKS Turbo Timer $40
Alternator $55
Castor Rods $40 each
Front hub $20 each
Front upper control arm $20 each
Front lower control arm with ball joint $75 each
Front 1/4 panels $150 ono each
Windscreen Washer bottle $20
Radiator overflow bottle(missing cap) $20
HVAC Fan Blower: $20
HVAC unit: $100
Dashboard plastic Garnish inc vents and buttons $100
Instrument Cluster Garnish: $30
Hicas sensor unit for standard steering wheel: $10
Indicator Stalk assy: $40
Steering wheel surround (Has small mounting holes where turbo timer used to be): $10
Sold:
Engine RB25DET (inc turbo, intake, exhaust, loom, ECU, airbox, clutch, everything)
Gearbox
Bonnet
Headlights
Bumper & support
Radiator
Radiator support
Castor rod mounts
Front Brakes; 4 spot calipers,Rotors.
Air Conditioning compressor
Air Conditioning condensor
Steering Wheel
Dashboard
Glovebox
Climate Control button assy
Located in east suburbs Melbourne. Will ship interstate at buyers expense.
Direct deposit or cash only.
https://www.sau.com.au/forums/topic/31465-wrecking-r33-gts25t-black-ser1-melb/
  • Replies 90
i will get the dash garnish from around stereo and steering wheel if in good condition + i need the plastic trim from drivers arm rest + plastic from around the gear stick and cig lighter + also need plastic from under dash that cover all of the fuses(under steering wheel)
and i also need the dash pad if in good condition is it possible to get these parts sent anywhere in vic?
SkylineGeoff - I am not certain whether or not the recepient of the engine requires the air con compressor, I will get back to you early next week.
Predator - will answer your Q on Saturday by the time I've pulled it apart that far.
EnricoPalazzo - Sorry dont have rear half of car, should have mentioned in first post.
lindsey34, check PM
--edit--
dave, sorry to you too, I should have mentioned it was only a complete front cut, I'm missing everything from behind the gearstick. No doors unfortunately.
gtrGhosTDoGG11 - no, why do people ask for the control panel? Is there a common problem that the windows dont want to move with it? I've repaired one in the past, it was only dry solder joints. They dont look dry, use a relatively powerful electronics soldering iron (30w so no plumbing irons :() and go over each joint. Should work afterwards....
Bozz thanks for quick reply. The reason I am looking for it is that in the bottom of the pocket there is a screw which holds it down. The plastic has cracked in it so its not being held down.
I guess I could probably fix it now Ithink about it :S
Bozz
as well as the other enquiry I made regarding the A/C comp, I'll be happy to take the Steering wheel off your hands at that price. I'll wait for an answer on the comp before arranging to come and pick it up.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
