gday guys just a quick question, im doin a +T conversion to my rb20 and am running the stadard turbo engine loom, just wanted to know can i run r32 gtr injectors without changin the loom? will these just pop in or do i have to tap the loom with gtr injector ends?
much appreciated calv..
https://www.sau.com.au/forums/topic/314715-gtr-injectors-into-gtst-loom/
They are low impedence injectors so you will have to buy a GTR resistor ballast or make your own with some resistors from Jaycar, forgot the voltage and ohmage sorry. Basically you cut the power feed to each injector, connect each one to a resistor(or wire on the resistor ballast), then connect the power feed to all of them. Also the plugs aren't a direct fit, the RB20 ones have a locating tab, I just filed these down and it works fine, other people stress out and buy the correct injector plug which you can get from Repco.
ah cheers mate sounds like a bit of muckin around thou might just go an aftermarket set arond the the same cc's
http://www.skylinesaustralia.com/forums/Gt...det-t62674.html
DIY guide ^^^
its worth the hassle, saves you plenty of $$ compared to typical aftermarket injectors.
Thats the inefficient way to do it :D
This is the way I did it
http://www.skylinesaustralia.com/forums/Gt...20-t256804.html
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
