For sale: Power Fc for series 1 rb25det
Price: 1200 firm.
Extra Info: Currently have this running in my 180sx,tuned with light mods (fmic,pod,exhaust). At 12 psi,194kw at the wheels with dyno sheet. Runs really well.
Reason for selling. Chasing a different set up.
Pictures: Will get some up tomorrow in the day,pretty sure everyone knows what they look like.
Contact Details: Pm but for faster replies txt or call me on 0433 604 913. Rick
https://www.sau.com.au/forums/topic/314771-fs-power-fc-hand-controller-rb25det/
only is its a s1 motor it wount work on a s2 r33 motors the pinouts are diferent i tryd using a s2 power fc it didnt work
Edited by pozesd
Just sold guys.
It would of worked in ur r32gts as long as it was a series 1 motor. Actually the guy who bought it off me had a series 2 rb25det,i asked him to make sure if it is compatable before buying it off me. So he searched around and said it should be okay. I hope he is right.
Please delete.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
