I'm looking to get heaps done in the near future to my GTS25T and a GReady manifold may be on the cards .
I did speak to SK ages ago about larger throttlebodies and he didn't think there was much it it even for a Modified RB25DET .
I'm just thinking that a larger throttle wide open may do something for an RB25 to get from the pre to the post boost state .
I don't know what the std TB size is on an RB25 or VH45 though I believe its 80 or 90mm .
Out of curiosity is there anything suitable in between the RB25 and VH45 throttlebodies ?
Also where do you get raped least buying the GReady manifold , hint 2nd hand ok too if clean ...
I guess this may mean the 90mm MAF as well .
Cheers Adrian DP03 .
We use the Stock Throttlebody On the RB25 Powered 180SX Sportsedan I work on and never had trouble making 600+rwhp.
All you get from a large throttlebody is poor throttle control, I did a Power run on another Skyline Racecar with 90mm Throttlebody, at 20% throttle
the car made 440rwhp, This car was very hard to drive on the track so we went back to Stock 25 Throttlebody, No powerloss at all but Lap times were faster and more consistent.
I ripped out the electronic 72mm in mine and replaced it with a 65mm bore Ford throttle. I gained power right through the rev range so I dont think it will help anywhere but up top if at all.
Go too big and you will loose the low throttle resolution and it will "feel" quicker but only because for the same throttle input there is more airflow. In my opinion, most important is to keep the laminar flow through it by matching the throttle bore to the piping and manifold .
Saw an article in Autosalon magazine where they had a mildly modified (under 200kw from memory) R33 GTST with I think a Plazmaman plenum among other small mods. They dyno'd it, then fit a bigger t/b (again Plazmaman I think) & picked up something like 20-30rwkw throughout the rev-range... Been a long time, maybe even a few years since I read it so sorry I can't be more specific...
  • Like 1
NA cars gain but Not Turbo cars until you are chasing massive power.
This car is a lap record holder and runs a 55mm throttlebody. IP cars are restricted requiring massive low rev boost so throttle control is vital.
http://www.barnettmotorsport.com.au/index.htm
I did the same things as Scott (m35 stag) on my X-Trail and ripped out my electronic TB and replaced it with a 65mm SR20 TB...
It's hard to tell if it made any more/less power, cos i had a shat turbo and an eff off exhaust leak a the same time, but unless your shooting for 600whp+, a few mm in throttle bore wont make a huge difference.
As NIB said, it can become hard to drive, the throttle becomes more of an 'on' 'off' switch rather than a progressive increase of flow. throttle sizes are matched with different air flows, because consider: 20% opening on a 70mm throttle = 'x' amount of air, then consider 20% opening on a 90mm TB = alot more than 'x' amount of air... Thu it becomes harder to regulate the amount of air going into the engine.
None of this directly leads to more power, cos there is no more or less overall air that's entering the engine.
Edited by turbo x-trail
Yeah fair enough , just thought I'd ask .
Nissan really screwed us RB25 owners over with the different manifold pattern to RB26's .
I got interested in RIPS RB25 to ITB 26 adapters but I don't want to lose the idle air control or cold start bypass .
I'm also finding that GReady manifolds are serious money nowdays like probably enough to make some sort of 25/26 hybrid work if RIPS was asked for it .
I think we all know what the preferable system is , ITB's .
Cheers A .
VH45 is 83 mm,
cheer`s Chuckie.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
