Hiya,
Currently there is an Interclub supersprint series running in NSW between 4 cars clubs SSCC,WRX,HSV & Aroca.
Come join the fun and mingle with a whole range of different cars
You need a minimum CAMS L2s Licence to run and a good attitude.The car needs to be equiped with the normal track day/supersprint requirements..I.E Fire Extinguisher..check the sup regs for more info
We also now use Dorian Timing. It is a more accurate way of timing and you can hire them from us for the day.
Its $200 with the Dorain Timing Hire.. You must Hire one or you wont be able to be timed.
Please see the attached forms.
The Colour Groups are:
Green
Yellow
Blue
White
If you have any questions please dont hesitate to ask!
Jessica Nicholson
Secretary
Southern Sporting Car Club
https://www.sau.com.au/forums/topic/314817-interclub-supersprint/
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
    • R35 card MAFs are great, not a fan of the Z32
    • Long time no see, I haven't posted since 14 years ago... To cut to the chase, R32 GTR. dead stock. Split wastegate hose = stock turbos were overboosting = front turbo's exhaust wheel has shattered. Have done a compression test following this and the results are (dry, cold) - 120 / 60 / 75 / 110 / 150 / 150. Haven't bothered with a wet test or leakdown test. The results definitely support front turbo failure (on 1-3) however the low compression on #4 is concerning too. Can anyone share their experience of when their turbine wheel shattered and damaged their motor - and what work needed to be done afterwards? Pistons? Rings? Valves? Throwing in the bin or salvageable? Motor is 100% stock. Will be getting it looked at further soon - I don't have a borescope and head hasn't come off (yet).
