!!!!PRICES ARE NEGOTIABLE!!!!
Rb25det from r33, all there, still in car, hear running.
It's making way for an rb26 conversion.
may also include alternator depending if my rb26 one has the same plug.
Car has 125,xxx on it, and its not the original engine, so i can only assume the k's are less than that....there is a sticker on the timing cover that says 80,xxxks but its in japanese.
EDIT: took timing cover off, has a PitWork timing belt, so HAS been changed
Compression test shows :
Cyl 1: 155 psi
Cyl 2: 155 psi
Cyl 3: 154 psi
Cyl 4: 159 psi
Cyl 5: 157 psi
Cyl 6: 155 psi
$1900 $1700 or nearest offer.
HKS fmic kit to suit r33 $650. $450
take it with rb rb25 setup, and you can have the lot for $2200$2000
I will not sell the Intercooler kit unless the motor is sold first.
located in dinmore, can deliver to brisbane if you cant organise it...might cost you a carton though.
PM or 0430087070
cheers
Jason
https://www.sau.com.au/forums/topic/314839-rb25det-complete-price-drop/
  • 3 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
