Ok, i am having trouble with my P2k on my S14 with a RB26. It ran prior with a differant engine management, but the identical setup will not work for me when i am using the haltech ecu. Here is a copy of my map
http://www.mediafire.com/?1hijydmygmi
its just got 1000cc injectors, i am trying to run this VE. I have the haltech wideband tied into the ecu wiring harness but there no way to make sure its working properly. This is a map for the e11 that i modified to suit my application. Like i said, on my other standalone ecu the car starts and runs fine.
Hopefully someone can look at my map and decide what i should do
here is a copy of datalog
http://www.mediafire.com/?5wndyyjkw2k
any help would be appreciated !!
  • Replies 68
When you convert a map to VE, you need to redo the fuel map from scratch. if you have a look at the VE R32-R33 GTR maps that come with the Haltech software (for platinum pro) you'll see what I mean.
How come you chose VE over milsecond timing?
how much power you aiming for? with 1000cc injectors i assume you going for big power, your target AFR table looks a little lean.
Also your engine cc is set to 3000cc, it should be 2568cc (unless you have oversized pistons)
Edited by sav man
ahhh ok, the engine is slightly over 2640 it should be saved in map grrr lol i will look at it now, i have a holset hx35.. but its not installed yet, i wanna get car running good before i install it
also i went with VE for ease of tune with closed loop, i know i wont make the most power but it will be consistant and reliable
did you have a look at the map for the R32-R33 Platinum Pro? Also when you say it doesn't start, does it turn over? Does it sound like it wants to start?
Edited by sav man
i looked at the maps and changed almost everything but i still didnt have any luck, i was told to check the home channel to make sure it was doing that for inj pulse and that was ok. it just cranks and no turn over,, doesnt even sound like it close either
hmm i noticed in my fuel base map, there is not a fuel setting for 0 rpm and on the pro there is a fuel setting, i think my car cranks around 130 rpm ish, so i think i found the problem right there but i cannot change it
have you checked to see if all the sensors are working?
on the 30x30 map try setting the cells around idle to about 40%. also might try changing the load sources to TPS and not MAP, as the rb26 has ITB.
tried changing the value to 40% i am going to go over the timing one last time, and go over all sensors, they look good, but tps might have a problem. its actually a rb25 with rb26 harness, and a q45 tb
Edited by stricnynel0s
About that TPS, had a problem with a customers EVO IX, the Haltech (PS1000) ECU hadnt registered that the TPS was connected, though it was, so it simply kept it from starting! Solution was to disconnect and connect it up again :D
Have you had time yet to check if it gets a spark when you turn the key, or if the sparkplugs got fuel residues showing that they're getting fuel? Also we had a problem with the cold start settings, might be because of the fact that its still snow here, but it was not getting enough fuel to start at these the low temperatures.
Good luck :P
When you turn the key on do the pumps prime? also when it's cranking, does the software display any rpm, that will show you if the CAS is working properly? the same page of the software should also have the TPS signal. Are you using a plug and play harnes?
ok i made some progress, the timing needed to be adjusted slightly, i set it to 0 and locked it and adjusted it that way, once i was done i unlocked it. now with a little throttle it wants to start up but dosent go all the way. i am also confused about if my wideband is being seen, i tied it into the factory side of the harness its the haltech wideband but i dont see any calibration options or anything reading it, i wish i could make it display AFR and not voltage, also i am in NJ (usa) been like 70 degrees whooo!!!!
and yes pumps do prime up, i am getting a rpm displayed of around 150-300ish i am using a patch harness, the tps signal is looking awesome, actually i have a question it says its 100percent for tps but when u push the throttle in it goes down kinda like an opposite
Sounds to me like your TPS wiring is backwards if its reading 100% at closed throttle & going down as you push the pedal...
yeah lol i made the change for that tonight, now i just gotta mess with it again tonight wish me luck, i was told i should of done an ignition lock at 15 degrees and not 0, sucks i am alone and dont have a helper
A mate was having problems with the base map supplied to him with his Haltech when trying to get his RB24 running.. if you want, I can send you the map from my stag. It's an RB25 Neo though but it helped my mate get a base to work with for his RB24 so might help get some of the basic parameters setup for running an RB.
Forget about the wideband until you actually get the engienrunning - O2 is ignored until constant throttle (cruise) conditions).
RBs like LOTS of ignition timing to start - in the order of 40 degrees.
i hate to spam my own thread, but when i did a wot and closed read voltage on the TB, it gets the proper voltage, but the reading still says 100% throttle. i configured it from the main, inputs and TPS, if it helps i am using a q45 tb, i was able to make it come up as 0 throttle by setting the voltage on both 100% 0% the same. now it looks like the fuel inj are working, but plugs look very bad, i am going to change them in morning and go frm there. so now my issues remains, car wont start, car always thinks its at WOT unless i unplug tps or adjust voltage, but it reads a voltage when i goto WOT or CLOSE throttle. but i can verify that the car is set for 15 degrees of timing when i did the timing lock on 15 which i was told is btdc. anything else i should check ?
What wideband you got? The one i got from haltech (innovative from memory) needs to be configured in the setup (Press f4), and you can set the AF vs voltage table, and the instrudtions said you need to be very particular with the wiring. But the car should start without the wideband.
Sounds like your TPS is on the wrong way, i think from memory you can change the 0% and 100% voltage values. ie the base map might be wrong, not the wiring. Having said that, i swapped a E11 out for a PFC on the weekend, and needed to change the TPS wiring to get the PFC to work, so the Haltech might need the wiring chaged from the factory settings.
Factory base timing is 15deg for RB20-25 from mem, and 20deg for RB26
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
