i have the new haltech wideband. i checked the tps and the way its made it can only go on one way. its weird, like i said i opened throttle and did set voltage to make it like lets sat 4v at 100% and i closed it and did a set throttle for 0% and it was 0 volts. seems like and voltage adsjustment i make forces it to be seen as 100%
  • Replies 68
i have the new haltech wideband sensor, the sensor also will only go on one way. its weird. i did a calibration for it yet it still reads 100% throttle. But it reads the voltages in between. like i opened it all the way and clicked set voltage for 100% than i closed it and did the same thing. it gave me 2 dif votleags liek 4.89 and . 38 but when i in put them it still says 100% and i switch them it still says 100% but when i made them both voltage for when its closed it says its closed now but always stays at 0 % now, at least i can get it started from there and trouble shoot it hopefuly
ok i havent messed with tps issue, but car starts up but turns off immediately, gunna try playing with throttle and seeing what i can get it doing. also when it goes, it backfires and pops
* ok something weird i noticed. i did the ignition lock, to set timing, to match that but when i look at degrees on crank pulley and whats displayed at ignition base its completely differant
Edited by stricnynel0s
yes, i did the ignition lock for 15 and adjusted cas till it was at 15, but my friend heard backfire and popping and thinks its still a timing issue, and the tps shows 0 right now without me touching it. where should the ignition base and advance be on the ecu manager or actually what should they reflect, and is it possible my trigger settings are off ?
i am about to get ready and give up, i tried everything literally for hours on end, my old engine management works 100% this dosent work at all, there is no shop close to me with experience with the unit without going 120 miles minumum, and i cannot drive it so i am stuck not only paying for tune but liek 300 for the tow. i sold my maf and my old wideband so i cant even hook up my old ecu to get the car running.... at this point i can literally do nothing....
when you got it to run, and you said it was poping backfiring. was there great clouds of black smoke/fuel coming out the back? did you try adjusting the fuel table to get it to idle? you running the aac valvle? And what base map did you use? the RB26 or the RB25 one?
its a rb26 one, with VE turned on and all values are set to 45% didnt see any smoke, just lots of smoke and i can hear the compression stroke noise, i defintaely thinks its a timing issue, i can make a video and upload it to tonight maybe to show you. it literally turns on and stays on for one second, no amount of throttle or anything will make it stay on, and honestly i gotta open throttle a bit just to get it to do that sometimes. i am running thr aac valve. i didnt think it mattered which base map i used since i wsas doign ve, and i knew rb cas was the same on 20-26 except neo. do you perhaps have a map i could compare it to ? also man i want to thank you man i appreciate the help your giving me i hope we can get it running !!
try bumping the fuel % up and down, I grabbed the 45% off a GTR running a platinum pro with VE. but that's only running 440cc injectors.
Also in the software you can load a diagnostics page, which has all the sensors, and the inj ms. (view menu>load page>diagnostics) but this mich only be on the latest version of the software (1.0.7)
you should probably check your plugs, as if it's been over fuelled, they are probably rooted.
Edited by sav man
I had the power and earth wires switched when I wired the TPS up and consequently the TPS signal was reversed as in your case. Swapped them around without any issue. That said my car ran ok just had a nasty deadspot down low until I fixed it.
It sounds like the timing the computer is seeing and the actual timing are quite different. Might explain why it will run initially with timing locked at 15 degs but then stall once the revs increase.
should i just change their pin location than ? there is only 2 wires on a 3 wire plugs used. i havent tried to start it with timing locked at 15, i just did it to set timing, can i try that and lock it at 15 start it ?
yeah i changed the plugs and it did make the world of a differance, but still same symptoms, its just sooo annoying cause only haltech gives me these problems
you tried pull some fuel out of it? Try starting at somthing low like 10% and then try and start it, then keep bumping it up till it states. if changing the plugs made it better, i'd think there is too much fuel.
if your tps is reading 0% the car should still idle
Edited by sav man
you using an external map or the internal one? can you pop your latest map up?
i am using internal map sensor
and here is my latest map, it dosent have the 10 fuel setting but same map
http://www.mediafire.com/?bzrnxzwmemk
i'll have a good look at it when i get home from work, did you try other values apport from 10%
Do you know the model of the injecters, cause i think the lag time will need to be reset in the Haltech, as they will most likely be diferent to the oem 440cc ones.
rc eng inj, and that was it honestly. i can try more later i was going to try 5 but i dont wanna go lean and make engine go pop lol
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
