up for sale is my s13 silvia,its been defected for too low.........regency job
registered as a ca non turbs but will chuck in some brakes to change it to a registered sr
already have standard suspension in and looks like a 4wd for regency.
i was over it before it got defected but yer i dont have the time now to f**k around with it
parts that will be thrown in for free.
standard sus,aswell as the aftermarket shizz
17 inch rims
NISSAN S13 SILVIA
MOTOR
T25 TURBO BOOST SET TO 14PSI
STANDARD RADIATOR WITH THERMO FAN
MANUAL BOOST TEE
FRONT MOUNT INTERCOOLER WITH REALLY SHORT PIPING(HAS AWESOME RESPONSE)
FULL TURBO BACK EXHAUST 3 INCH GOING INTO 2.5 STRAIGHT PIPE WITH CANNON.
190,000KMS ON THE CHASSIS,PRETTY SURE THE GUY I BOUGHT IT FROM SAID IT WAS A LOW KM IMPORT MOTOR THO.
STANDARD 5 SPEED BOX
EXTREME HEAVY DUTY CLUTCH.,VERY NEW AND IS VERY PUNCHY
INTERIOR
DEFI BOOST GAUGE
DRIFT BUTTON
AFTER MARKET SHIFTER
FULL SOUND SYSTEM
1 CRACK IN THE DASH,OTHER THAN THAT THE INTERIOR IS CLEAN AS A DINGO'S DINNER PLATE
EXTERIOR- STANDARD TWO TONE
UNDER THE CAR
BILSTIEN SHOCKS AND SPRINGS- PRETTY GOOD FOR THE STREET LOWERED A FEW INCHES
NEW BUSHES
RANDOM BITS
BATTERY RE LOCATED TO THE BOOT
WAS DYNOED LAST WEEK AT 11PSI AND PULLED 165KW AT THE WHEELS SAFELY WITH NICE AFM'S- SINCE THEN IVE PUT THE BOOST UP TO AROUND 13-14 PSI
please txt or call sean on 0401823220
Attached thumbnail(s)
https://www.sau.com.au/forums/topic/314954-s13-silvia-sr20det-170kw-atws/
  • 3 weeks later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
