old oil stank of petrol and had about a litre too much in, bear in mind i run twin pumps and 1000cc sards. wont take long at 8.0.1 afr to do that.was changed after afr set and prior to dyno run,car was never driven with the contaminated oil in the motor
sounds very bad to me.....fuel is a rubbish lubriant, almost as bad as coolant :D
but assuming you changed it, most of it was removed (no oil cooler?), and the problem was fixed that may not be it.....you don't have the oil that just came out of it?
  • Replies 76
right guys a further development. looks like we have looking in the wrong place. i now suspect something has gone through the engine.from where i am not sure. below are pictures of the head on number 5 the one that spun and number 5 piston crown,, i was running a 1mm headgasket. question is whatever caused these marks would it be enoug on a 1mm gasket to jam the piston enough to cause the crank to hit the bearing momentarily?.
i have stripped the turbo, nothing wrong there?. had a look in the exhaust there is some very small shiny magnetic fragments?. any idea where something that could do this had got in from..
The indentations look a lot like spark plug electrode mate.
I once left mine at a "reputable" tuner for dyno-ing after a forged rebuild and was not happy with the results, (less power everywhere with higher specs) and after lots of head scratching I pulled it out and found the pricks had melted plugs in it (dash 8's) and simply put new ones in it and gave it back to me.
yeah +1 for detonation.
would also explain why the bearing has gone on no5 too.
You would think it would be across the board but and evident in all cylinders. I suppose if no5 injector had issues there's a possibility.
What do the other cylinders looke like?
odd thought... but had you used a die grinder on or near your intercooler piping or anything that would have been open on the intake setup weather it be plenum, TB, ic piping, comp housing, intake pipe....
that pitting either looks like the result of ceramic bits off a sparkplug or metal filings from something not being cleaned properly after working on it..
hi Cartman, no mate if i ever do anything like that the cars is not in the garage, you can see some die grinding work on the head in the pics, i have over the weekend fully ported and polished the head. its away now for a light skim. now the piston tops are cleaned of they almost look as good as the day they went in..lol
all the valve guides in 1 piece? ive seen the inlets fracture and do similar damage.
that wont be the cause of the damage. its not detonation.
to only dammage 1 bearing its only oil contanimation. fron the look of it something has been sitting in the crank and got loosed. did you have the crank grubscrewed when it was first built?
of have you recently put on a oil cooler?
hi t04gtr
cars has always had a 19row oil cooler fitted.feedsin the top and drain at the bottom, the oil filter is mounted low on a remote so when you do and oil change the cooler empties too.
no grub screw mate, collar was sweated on and has never moved
no valve guides damaged at all.
i find it hard to believe det after looking at the pistons..
still wondering why?.
bernie
If you had lost an engine at 900klm you would feel the same way as Marko. The engine in question was a low revving item that was never put under stress...N1 went bang.
GTRNUR...correct...the mains are all shiny from eating rod bearing material.
So what kind of revs was it pulling and under what circumstances did it go bang? Drag/circuit?
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
